Old 09-20-2017, 07:40 PM   #1
Spacers for 18" Twists (Don't kill me)
I searched but I could not find the info. I recently lowered the car with H&R springs. I am fine with the height and ride, but the wheels look very sucked in now (stoick 18" twists). Does anyone have experience with this? I would like to add some spacers. Nothing too extreme. Just want to improve the look for the street. I have stock size tires. Recommendations?
lskolnick is offline   Reply With Quote
Old 09-21-2017, 05:32 AM   #2
Artist, 986S tinkerer
NewArt's Avatar
10 to 15mm spacers could work nicely. Use one of the online tiresize sites to verify the fit by changing the wheel offset.
Old 09-21-2017, 07:46 AM   #3
JayG's Avatar
I run 20 mm in the front and 15 mm in the back with stock 18's with no problems
Old 09-21-2017, 08:13 AM   #4
Where did you get the spacers, and the longer bolts?
Old 09-21-2017, 09:10 AM   #5
I run 12mm front and rear. I got the spacer on Ebay and used wheel studs/nut instead of longer bolt. Got them from Motorsports Hardware.
Old 09-21-2017, 12:14 PM   #6
I run the 18x8s up front with a 15mm spacer and the 18x11s out back with a 13mm
deathsled986 is offline   Reply With Quote
Old 09-21-2017, 03:42 PM   #7
Administrator
I run H&R spacers. Good quality: Porsche Boxster (1997-2004) - Axles, Bearings & Differential - Page 4 Extended bolts are on the next page.
Luccia at Pelican Parts is offline   Reply With Quote
Old 09-22-2017, 02:03 PM   #8
JayG's Avatar
I got the spacers and 95mm studs and lug nuts on ebay
I track the car, so I am changing wheels a lot and studs make it much easier
Old 09-22-2017, 02:16 PM   #9
NewArt's Avatar
Jay, I'm interested in changing over to studs and lug nuts. I have an ET50 on the front with a 10mm spacer and an ET40 on the back with no spacer. What do you suggest?
