Old 09-03-2017, 07:33 AM   #1
pidj's Avatar
Liner question
Picture this: In my 2001S, as you follow the liner back towards the plastic rear window (on each side) the material 'floats' (not sewn in). On the underside of liner material (in this area) there is a sticky residue (on the stayfast canvass too) that soils the plastic each time you collapse the top.
Is the liner supposed to 'float' in this area?
If not, can I apply some adhesive to re-tack it?
Just curious if anyone else experiences this ... I couldn't find anything in the forum.
2001 Boxster S, Guards Red
pidj is offline   Reply With Quote
Old 09-03-2017, 10:39 AM   #2
That flap is heat sealed to the top and is held onto the back of the frame. Just had this happen to mine. Try 3M VHB tape. I did a similar repair: see the recent thread under my name
"Glass in top not sitting properly"
Cbonilla is offline   Reply With Quote
Old 09-04-2017, 11:41 AM   #3
pidj's Avatar
Thanks, my issue is not in the same area, rather it is inside the cabin at the rear 'quarter area' of the liner. I'll get some of this tape and see if that works though!
