08-26-2017, 10:35 AM
Accidental disconnection
I was cleaning the drain holes in front of the passenger side (NA-wise) and saw this disconnected piece ... I can't find where it goes. Does anyone know?
2001 Boxster S, Guards Red
08-26-2017, 10:45 AM
It seems to be the venting tube for the battery fumes
08-26-2017, 11:04 AM
Thanks Gilles! Now to locate a vent attachment on the battery ... it's an aftermarket the PO put in ....
08-26-2017, 11:07 AM
If your battery is of the AGM variety, it will not have a connection for the vent line. Lead acid batteries will either have a tube, or a port for a tube connector.
08-26-2017, 11:20 AM
I'm seeing a hole on either side but the porsche attachment won't fit. It also appears to be a BLEM replacement too .... does this look like an AGM? I'll have to leave the vent tube tucked away ...
08-26-2017, 11:52 AM
FYI: BLEM indicicates a blemished battery. Usually a cosmetic defect or a battery that sat on the shelf for too long and was stripped of its decals and sold at a discount.
Are you sure that's a vent hole?
If so, you'll just need to make an adapter.
08-26-2017, 11:57 AM
unfortunately I'm not sure ... there's a matching hole on the other side too ... as you eluded, there are no stickers etc. to aid identification.
08-26-2017, 04:26 PM
I'm having the same problem with a recently purchased '04S. PO replaced battery and failed to swap out vent tube adapter leaving the battery unvented.
Check out this link:
https://www.amazon.com/BMW-Battery-Vent-Hose-Elbow/dp/B01L7U4MUU/ref=sr_1_fkmr2_1?ie=UTF8&qid=1503787574&sr=8-1-fkmr2&keywords=battery+vent+tube+elbow
The listing is for BMW's but I cross referenced battery requirements for the compatible BMW's in the ad and the 986. They were the same.
I'll be ordering a pair.
2002 Boxster base - Seal Grey, 5spd trans.,ROW M030 upgrade, FVD Brombacher software tune
2004 550 Spyder Anniversary Edition, #1541,Tip, TechnoFix DOF IMSB upgrade
08-26-2017, 04:48 PM
Don't know who told you this old wive's tale? (And you are aware that AGM batteries have lead-acid chemistry?)
Even if it's only for an exceptional circumstance, (e.g., battery or charging system malfunction), having a vent sure seems like a good idea to me when the battery is located in an area without plenty of natural ventilation, (and where sulphuric acid vapor-induced corrosion would be so damaging and expensive to repair) like is the case on our cars...
Originally Posted by SC-986
Nice find! That looks just like what I've got on my AGM battery...
2001 Boxster
08-26-2017, 07:29 PM
the holes on both sides are the vent hole. You're missing the 90 degree adapter. I'm sure pepboys etc sell the adapter. It's a small right angle adapter.
If would have it connected as there are quite a few reported exploded batteries, especially if you use a battery tender/charger
08-26-2017, 08:14 PM
PO installed a Duralast Gold from Autozone which has vent ports on both sides of battery. Do I need to plug the unvented port or add another vent tube and "T" into the existing tube?
08-26-2017, 08:46 PM
Crazy. I buy two AGM's each year for our waverunners...never have vent ports.
08-27-2017, 08:04 AM
It would seem the determination of whether or not a battery has vent ports is application specific. I have SLA's in my Ram 1500 and Jeep Wrangler and they don't have vent ports.
08-27-2017, 03:44 PM
I'm going to look around at the batteries next time I'm in Sams!
