Old 08-25-2017, 03:51 AM   #1
DrCactus's Avatar
Lightbulb HELP: O2 Sensors - part #
Hey guys, I am looking to replace the O2 sensors on my 2001 S but I need some help figuring out how many sensors I need to buy. Part numbers, how many sensors are there and location of them. Some items I read say Left and Right Downstream sensors (2) and another left and right Upsteam sensors (2)...total 4 ? Do I need to replace all 4 sensors if I get code P1130 or more likely just one side ?
S
DrCactus
Old 08-25-2017, 05:11 AM   #2
Changing all four sensors needlessly is nonsense. P0130 is for the sensor ahead of the three way cat on bank 1.
Go to Sunset Porsche's parts website and enter your VIN number, the system will kick out the exact correct part number for that sensor for your car.
Old 08-25-2017, 05:17 AM   #3
Dave80GTSi's Avatar
https://sites.google.com/site/mikefocke2/oxygensensors
2000 Ocean Blue Boxster S
1980 Ferrari 308 GTSi
2019 Alfa Romeo Giulia Ti Sport AWD
Dave80GTSi is online now   Reply With Quote
Old 08-25-2017, 06:16 AM   #4
DrCactus's Avatar
I am actually getting FAULT CODE p1130 not P0130
DrCactus
Old 08-25-2017, 07:10 AM   #5
The 0130 is a typo, as was my bank info, it should be on bank 2.
Old 08-25-2017, 07:57 AM   #6
DrCactus's Avatar
Ok thanks... Is bank 2 downstream O2 sensors ?
DrCactus
Old 08-25-2017, 08:35 AM   #7
Upstream means ahead of the three way, downstream means after the cat.
Old 08-25-2017, 11:36 AM   #8
And Bosch makes the part for Porsche. So the correct part number for the Bosch part (15182) and you are good. Don't need a P-car mechanic, any muffler shop can do. They did mine on an '01S in 15 minutes and charged me appropriately. Heck 10 of those minutes were waiting for the cats to cool down on the lift so it was safe to work on.
Old 08-26-2017, 11:01 AM   #9
As many others on here have also given story to, my 45 minute, change 1 sensor turned into a 4 week miserable experience....just FYI....soak that puppy in penetrant and have a tap handy...M18 I believe
Current: 2000 Boxster S....2018 Clubman JCW
Previous: '71 914 2.2 - TX license plate: "E-GO"....'73 914 1.7....'74 914 1.8....'73 914 2.0 - Saturn yellow with all original 2.0 options- R.I.P..... '74 914 1.8 with 916 body kit.... '72 914 1.7 - my very first car
Also: '09 Cooper Clubman....'90 Miata.... '80 MGB.... '76 TR-7
Ebell914 is online now   Reply With Quote
Old 08-28-2017, 06:32 AM   #10
DrCactus's Avatar
Does anyone have a website I can order these sensors from? Who ship to Canada or located in Canada
DrCactus
Old 08-28-2017, 11:56 AM   #11
I just checked my purchase records and I ordered Bosch universal 4 wire #15738 for MY02-S from EBay thru a guy Sparkautoparts. May be different for your year. Hope it helps
Lapister is offline   Reply With Quote
Old 08-29-2017, 03:27 AM   #12
DrCactus's Avatar
Can someone tell me if I should order Bosch part (15182) or (15738) ? I seem to be getting both answers to my issue... these are not cheap so I don't want to buy wrong ones....
DrCactus
Old 08-29-2017, 03:37 AM   #13
DrCactus's Avatar
When I look up my car on some sites I get this number for the BOSCH 13806 Downstream part... which one is correct ?
DrCactus
Old 08-30-2017, 06:42 AM   #14
kirkandorules's Avatar
Bosch 13806 is what you want. The other part is the same sensor but without the harness, which is way more rigmarole than its worth.
'99 986 Ocean Blue Metallic
'87 924S, winter beater
'17 VW Golf Sportwagen, for when I need extra seats
kirkandorules is offline   Reply With Quote
Old 08-31-2017, 03:48 PM   #15
This whole process of verifying the correct sensor was quite the pain I recall. You definitely want the pre cat sensor or upstream that the ECU relies on for fuel management. I see your car is 01-S. If there is no difference between our years then 15738 will work. They were not that $$ maybe $28 a piece. Cut the original wire terminals and crimp onto new universals. At that point my p1130 went away and it hasn't thrown any codes. Have you tried swapping the sensors between the banks? This may verify the faulty or marginal one. Good luck !
Old 09-01-2017, 10:32 AM   #16
pidj's Avatar
Try these guys (just type in the part number on the search box):
https://order.germanparts.ca/search.html
They have that part ~159.00 Cdn, or 15.75 US (LOVE the exchange :P)
2001 Boxster S, Guards Red
pidj is offline   Reply With Quote
Old 09-07-2017, 03:53 PM   #17
Replacing O2 sensors in my 02. So am I hearing correct that they are all basicly the same and that only the connecter changes? Mine has the older oval connectors on both front and back, but having a hell of a time locating parts with correct connector.
kuhndog is offline   Reply With Quote
Old 09-07-2017, 04:53 PM   #18
Bosch part numbers from the link posted above.
15182 Oxygen Sensor - OE Type Before Catalyst
15183 Oxygen Sensor - OE Type After Catalyst
if you had followed the link above.
Available now on amazon or ebay. Pelican probably. Or your favorite online discount shop.
