Old 08-15-2017, 09:42 PM   #1
Pdwight's Avatar
Something to think about
If your car did not come with OBC or cruise control and are thinking of adding one or the other....usually OBC is done first. Have your shop enable both, I cant see where it could cause a problem...it would simply not be there and would not be plugged up. Then in the future if you decide to add this feature it will save you a trip to the shop and possibly a service charge to have this activated....you simply add a harness and you are set to go.
Old 08-15-2017, 09:50 PM   #2
This is a great idea. My car was already enabled, but I didn't have the stalk or the harness, until I met you. Just installed the stalk and the harness tonight. Happy to say I can now use all the OBC features. Thanks!!!
lskolnick is offline   Reply With Quote
Old 08-15-2017, 09:58 PM   #3
Pdwight's Avatar
Thank You
I appreciate your order and glad everything worked well as it should. It should also look OEM and blend with your factory wiring harness and not look like something cobbled up in a garage.
Dwight
