Old 08-13-2017, 09:24 AM   #1
JBauer's Avatar
Rollbar covers
Is it just me or is it a B to get the mesh inserts into the rollbar after installing a Klisstle cover. I just can't get them to fit now. Anyone come up with a solution to this?
Old 08-13-2017, 09:39 AM   #2
My solution was to sell the rollbar covers.
The mesh just doesn't fit with them.
Old 08-13-2017, 10:04 AM   #3
JBauer's Avatar
You got rid of them? ☹ Crap I knew you had some and I figured you had a solution.
Old 08-13-2017, 01:52 PM   #4
Yeah, I guess that wasn't very helpful.
I got rid of mine because I felt that the white was too bold. I managed to squeeze one mesh screen in, but the tabs were so bent from the pressure that I'm sure they would have broken or popped out.
If I had kept the cover, I would have just not used the mesh screens.
Old 08-13-2017, 03:19 PM   #5
JBauer's Avatar
I'm gonna keep mine on for awhile. Broke one tab on each cover trying to install them. Guess I should have test fit them before I painted and installed it. 🙄
Old 08-14-2017, 12:12 PM   #6
I broke 1 tab on each side but now they wedge in very nicely.
Old 08-14-2017, 06:05 PM   #7
JBauer's Avatar
Unfortunately I did the same and they still will not go all the way in.😐
Old 08-14-2017, 09:20 PM   #8
drew44's Avatar
Has anyone who has installed the Klisstle covers had issues with the top rubbing on them as it goes up and down. It is almost to the point where it causes the top to struggle. Just wondering if I am doing something wrong.
drew44 is offline   Reply With Quote
Old 08-15-2017, 06:39 AM   #9
mikesz's Avatar
I just don't use the mesh couldn't get them back in after putting on the covers. Wish I had tried to put the mesh in first then install the covers.
99 Porsche Boxster
Old 08-15-2017, 08:16 AM   #10
JBauer's Avatar
I know your pain 😭
Old 08-15-2017, 01:40 PM   #11
Dubaday's Avatar
Yeah same issue, I can't get the mesh inserts to fit after the klisstle cover was taped on. so I got rid of the mesh inserts.
I did however do a highway test with the mesh insert and without, not a difference that I can notice.
Also did a test with the middle windscreen removed, definitely won't do that again...
2000 Boxster S, SPEC stage 1 clutch, Fabspeed sport headers, Fabspeed secondary cat deletes, Billy&Boat muffler, EVOM air intake, Ben006's Custom Short Shifter, Pedro's TechnoBrace, Eibach rear sway bar, De-snorkeled, Fred's custom projector HL
Dubaday is offline   Reply With Quote
