-   -   996-613-980-06-A05 <-- Is that switch only available in the U.S.? (http://986forum.com/forums/boxster-general-discussions/68046-996-613-980-06-a05-switch-only-available-u-s.html)
Crib 08-03-2017 01:09 PM
Hi guys,
I'm about to do the OBC hack with a rocker switch.
I want to use the...
996-613-980-06-A05 *** MAT 2002- FOOTWELL LIGHTING
https://www.renntech.org/forums/uplo...9084_thumb.jpg
...since it's graphics looks most logical.
I have two questions:
1. Why is it called footwell lightning? It looks more like a garage open/close pictogram
2. Is it only available in the U.S.? I can't find it on any other webshop, and none of the US ones are shipping to Sweden :(
Cheers!
Crib 08-03-2017 01:44 PM
OK, so the genious who answers his own post.
I found plenty of incorrect data on other forums.
It turns out that my first question was fair, since what i want is not a footwell switch but rather a targa top swith
Porsche 996 Targa Roof Tocker Switch 99661311910A05 - 99661311910A05 | Design 911
JayG 08-03-2017 02:03 PM
Its actually a Targa top sunshade switch
NewArt 08-03-2017 03:26 PM
Or maybe PRINT and MULTIPLE COPIES
lkchris 08-03-2017 04:07 PM
Just in case ...
Many are mislead by the 101 Projects book that this mod requires removing steering wheel, etc.
In fact the lever for OBD bolts to the switch cluster and the entire switch cluster does not require replacement. So, if you can find a used switch cluster, just remove the OBD lever from it and fasten it to yours. The advantages being you have a logically marked switch plus you get all OBD functions.
Crib 08-03-2017 11:47 PM
Haha, good one :cheers:
Crib 08-03-2017 11:49 PM
Originally Posted by lkchris (Post 546054)
Just in case ...
I second that, the steering wheel does not need to come off in either case.
However i don't want the lever/stalk since i'm quite tall and I think they might be to close to my legs, and possibly break after some entry/exits.
lkchris 08-04-2017 08:55 AM
I worried about that, too. At 6 ft 3 in (190.5 cm) I'm having no problem.
