Old 07-27-2017, 01:26 PM   #1
2003 fromt clear headlights on a 1999 base, compatible?
Hi,
I have a 1999 base with amber turn lights in the fromt headlights. I want to change the look. Would front headlights from a 2003 be compatible with my MY?
And what about rear lights....compatible?
Thanks !
CDNIcecube is offline   Reply With Quote
Old 07-27-2017, 02:29 PM   #2
All 986 front, rear and side light assemblies are interchangeable.
Litronics would not self level without the suspension sensors, but clear halogens would swap right over.
Old 07-27-2017, 05:16 PM   #3
Thanks particlewave for the quick reply!
Old 07-27-2017, 07:10 PM   #4
Oops one more question if I may. The seller says that they are OEM xenon. They come from 2003 MY. Would I need a change in the 99 wiring harness or are they plug and play? Thanks!
Old 07-27-2017, 07:20 PM   #5
oldskool73's Avatar
should be plug n play still, the xenon driver box is mounted on the back of the lights and takes power from the same standard connection as the normal lights.
oldskool73 is offline   Reply With Quote
