Old 07-18-2017, 10:40 AM   #1
Administrator
How Many Miles Are On Your 986/987?
Our in-house Boxster "Carrera" has roughly 80k. It does not have the original engine, thanks to our tech article on the Carrera engine swap.
Post up yours below with how many miles are on the chassis and if you've ever had any major engine work done.
Luccia at Pelican Parts is offline   Reply With Quote
Old 07-18-2017, 11:41 AM   #2
110,000 miles on our MY2004 S. Runs great and uses next to no oil. Hope to have it for a long time.
Does have a Pedro/RS Tune IMS DOF.
Just replaced the trailing arms, but the rest of the suspension seems to have a lot more life in it.
1941 Dodge Luxury Liner Coupe
Old 07-18-2017, 11:46 AM   #3
MWS
Apx 43,000 mi, MY01. Just standard annual maintenance with exception of water pump and IMS upgrade (for piece of mind).
Old 07-18-2017, 11:58 AM   #4
133K on 2000 S. No major problems at all....great car!
Old 07-18-2017, 12:17 PM   #5
There Is No Substitute.
rick3000's Avatar
101k Miles, no major problems, although some of the minor ones have been expensive.
Old 07-18-2017, 12:23 PM   #6
heliguy's Avatar
116,000. A new engine was installed at 111,000.
Old 07-18-2017, 12:48 PM   #7
husker boxster's Avatar
2008 Boxster S Limited Edition - #5 of 250. Bought new 12/31/07, now has 56K mi. Bone stock.
2008 Cayman S Sport - #624 of 700. Bought 12/4/12 w/ 7400 mi, currently 52K mi. Mods include:
EBS sump baffle
Tarett adjustable toe arms
Tarett LCA bushing
GT3 frt LCAs
GT3 frt brake ducts
Function 1st shift solution
Steel braided brake lines
IPD plenum & GT3 TB
Track alignment (-2.5 camber frt, -2.1 camber rear)
1989 928 S4 5 spd - black
Old 07-18-2017, 12:57 PM   #8
Ciao's Avatar
38K stock 2001 S, Seal Gray
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 07-18-2017, 01:32 PM   #9
204,XXX 2002 Red S. I bought the car last year for $6k, dumped 3k into the cam chain adjuster. I believe this engine is the original, p.o. didn't know much. I have put 10,000 miles on it since I bought it and I drive the s**t out of it. I am hoping that one day it blows up and then I can either replace with a 3.8 or go LS3 on it.
02 Red S. 4th owner 198k miles , now 225k miles and still going strong.
rczap is offline   Reply With Quote
Old 07-18-2017, 01:32 PM   #10
fusionist's Avatar
28k, 2003 S. I got the IMS solution and a new water pump as preventative.
1962 VW Beetle
1966 Triumph Spitfire
2003 Porsche Boxster S
2005 Ford F-150 Monster Truck
fusionist is offline   Reply With Quote
Old 07-18-2017, 01:34 PM   #11
Chuck W.'s Avatar
30,400 miles 2001 S original engine & IMS no major work.
1995 Porsche C4 Cab
Old 07-18-2017, 03:02 PM   #12
Oldcarguy's Avatar
Just back from an afternoon drive 106,375 miles. Clutch and preventive maint water pump, LNE classic IMSB, etc at 103k. AFAIK from maint records provided only regular / expected maint and replacements performed during the car's life. No major issues of any kind (knock on wood).
Rgds, Fred
Old 07-18-2017, 03:06 PM   #13
You've drove the crap out of this car in the last year!!
Old 07-18-2017, 03:28 PM   #14
That's a pretty Boxster S you got there Oldcarguy
McHeinzky is offline   Reply With Quote
Old 07-18-2017, 03:41 PM   #15
03S, 70,000 miles. IMS done...no engine problems
Old 07-18-2017, 04:19 PM   #16
Oldcarguy's Avatar
Thanks McHeinzky! I feel in love with her the minute I saw her
Rgds, Fred
Old 07-18-2017, 06:29 PM   #17
68,xxx on my 2003 S all put on it by me! It's had the IMSB replaced with an LN Single Row Pro at 42k, still on the original clutch. Added ROW M030 Sport Suspension at 65k, not because the original suspension was worn but because I wanted it. Also added an under drive pulley, Mantis deep sump and stainless steel flexible brake lines.
Old 07-18-2017, 06:37 PM   #18
98 Arctic silver 986
tommy583's Avatar
98 with 122,000 miles. LN engineering dual row installed along with new clutch at 62,000 miles 6 years ago. Besides that AOS, front motor mount, water pump and low temp T-stat 3 years ago.
Old 07-18-2017, 07:20 PM   #19
1997 Tip, 2018 Macan
rexcramer's Avatar
The 97 has 26700 on it with nothing major so far. The 09S has 28500 and nothing major either. I really enjoy these cars.
Old 07-18-2017, 08:38 PM   #20
2001 986S. Rainforest green metallic. 86k total miles. 57k on original engine, the balance on a 3.6 Raby built high performance build. Final Solution added before it was available to general public. New M030
Suspension about 10k mikes ago as well as rebuilt 6 speed around the same time frame.
2000 Black 996 Aero, 2001 Forest Green Boxster S, 94 Midnight Blue 968 Cab, 1980 Pongee Beige 911SC Weissach Edition, 2004 BMW R1200CLC
ymkmkrz is offline   Reply With Quote
