Old 07-13-2017, 02:40 PM   #1
Bi-xenon headlight conversion
Rebuild my halogen headlights to bi-xenon with daytime running lights build in. What do you guys think of it?
garageclassics is offline   Reply With Quote
Old 07-13-2017, 04:56 PM   #2
Multi-Boxer Driver
Deserion's Avatar
Personally if you put a small shroud on the projector it would be perfect. Great work!
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 07-14-2017, 03:19 AM   #3
mikesz's Avatar
FANTASTIC! You should do a DIY! I have been wanting to do this for a couple years. I have bought the parts but haven't had the time. Can you post pics of them on? I really like the DRL.
99 Porsche Boxster
Old 07-14-2017, 11:55 AM   #4
I just finished the job! When i have both ready i wil post some pics with both headlights working. Thanks by the way!!
Old 07-14-2017, 04:03 PM   #5
As promised, both headlights completed! I'm pretty satisfied with the result..
Old 07-14-2017, 04:31 PM   #6
Looks great!
2002 Boxster 2.7 Lapis Blue
jrgill is offline   Reply With Quote
Old 07-15-2017, 10:47 AM   #7
Christian H's Avatar
Good job
Christian H is offline   Reply With Quote
Old 07-15-2017, 01:53 PM   #8
DarkStar's Avatar
Better than Lits by a Mile. I wanna clear my blinkers like that.
-Josh
2001 Porsche 986 Boxster RS2.7 Bi-Turbo
DarkStar is offline   Reply With Quote
Old 07-15-2017, 05:35 PM   #9
I am No. 1348
algiorda's Avatar
Don't the running lights obscure the light throw of the low beams?
algiorda is offline   Reply With Quote
Old 07-15-2017, 06:57 PM   #10
The bottom half of the reflector is the high beam.
However, with bi-xenon, the HID functions as both the low and high beam. The halogen high beam is only necessary for daytime flashing, which the OP will need to pass inspection.
You need shrouds. It looks a bit off without them and the light scatter is not ideal.
Old 07-16-2017, 03:57 AM   #11
shrouds.
Thanks for the explaination Particlewave! I haven't found the right shrouds yet. I really really like the ones nine8six makes! Think i've seen them on Rennlist...
Old 11-24-2018, 07:00 AM   #12
Hi, how do you get into the lamp to fit the bi-zenon and what are the bi-zenon units. Thanks
aviator at elstree is offline   Reply With Quote
Old 11-24-2018, 07:07 AM   #13
What bi-zenon units should I get for UK RHD
Old 11-27-2018, 10:50 AM   #14
redciv1's Avatar
You have to heat up the entire headlight to soften the adhesive. I believe it was maybe 250 degrees for 5-8 minutes monitoring. There is a video on Youtube for opening 986 headlight.
redciv1 is offline   Reply With Quote
Old 04-10-2019, 07:00 AM   #15
Purchase
Hi
Where can I buy these bi-xenon lights?
I have a 2001 Boxster (R21 RGF reg).
RobFerguson2009 is offline   Reply With Quote
