Old 06-08-2017, 11:56 AM   #1
Boxer won't start
My battery was failing on a 2003 Boxster base. Finally, I got the front hood open, replaced the battery, now the engine just turns over, but will not start. Car gas been sitting still for a good 4 months before replacing the battery this week. Any advise welcome. Yes it has high octane fuel in tank. Bob
icfbob is offline   Reply With Quote
Old 06-08-2017, 12:02 PM   #2
Need to check for fuel and spark.....
Fuel pump relay good?
Crank position sensor (CPS) failed?
Old 06-08-2017, 12:52 PM   #3
It turns over, it just won't fire.
Old 06-08-2017, 05:44 PM   #4
Beginner
Jamesp's Avatar
What dghii said. You need to check for fuel and spark. You can find multiple posts to guide you in doing that on this forum.
2003 S manual
Old 06-08-2017, 07:41 PM   #5
Pull off the vacuum hose at the throttle body. Have an assistant crank the motor and at the same time spray wd40 into the hole in the throttle body. If the car sputters then you are not getting fuel. No sputter means no spark.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 06-09-2017, 05:23 AM   #6
I am surprised no one has mentioned the crank position sensor. If it is bad you will get exactly these symptoms.
1941 Dodge Luxury Liner Coupe
Old 06-09-2017, 07:19 AM   #7
It was mentioned in first reply. To the OP, I know it may seem like you're not getting help, but you are. Our cars are like any other vehicle...no start is either caused by no fuel or no spark. The CPS is part of the "no spark" chain.
Not sure on the what the minimum voltage you should see while cranking but with my 84 Alfa, its possible to have a condition where battery is strong enough to turn starter but not strong enough to supply minimum voltage (~10.5Vdc) while cranking to enable the Bosch L-jet fuel injection. Result is cranking but no start.
Old 06-09-2017, 10:03 AM   #8
If the tacho is rising while cranking, then the crank angle sensor is OK.
2001 Boxster S, TipTronic in Seal Grey aka "The Imp"
2001 TE50, ESS in (now) Grigio Titanio Matallizzato aka "The Golden child"
TrumpyAl is offline   Reply With Quote
