Old 05-23-2017, 02:11 PM   #1
Christian H's Avatar
Lumpy idle and smell of fuel
Hi Gents,
My Boxster is a 1999 2.5 has covered 67,000 miles and has been pretty much trouble free during the last 10 plus years of ownership.
I have only covered 1,200 miles since the last major service last year but recently I have experienced a lumpy idle and a rich fuel smell that has now illuminated the orange check light on the dash, once on the move the car seems to run reasonable well although maybe a little down on power.
I cleaned the throttle body and checked the intake for leaks and checked the maf sensor (maf was changed a couple of years ago) last week but this made no difference at all.
A friend scanned for codes today and it came back with these generic codes:
P0300 Random/multiple cylinder misfire detected
P0301 Cylinder 1 - Misfire detected
P0302 Cylinder 2 - Misfire detected
P0303 Cylinder 3 - Misfire detected
If it had been one or two misfires I would probably have been looking at coil packs but with them all being on the same side I'm wondering if it could be the o2 sensor on that side of the engine?
Has anyone had a similar experience?
Any advice would be appreciated before I take it to my independent Porsche specialist.
Thanks guys
Christian H is offline   Reply With Quote
Old 05-24-2017, 09:51 AM   #2
Dave S.'s Avatar
I had something just like that happen when my alternator died last summer. My 03 Boxster only had 34k miles on it at the time. My mechanic said that the fuel injection system is very sensitive to voltage and he was a little surprised it ran at all. I'd start by checking the voltage across your battery terminals while the car is running to start with. I had less than 12 volts instead of around 13.5 - 14 volts like normal. I think I only showed around 10 - 10.5 volts with the car running when mine did that.
When that happened to my car, the first sign was a strong smell of fuel when idling and a rough idle. I had no dash indicator lights go on, which was really surprising.
Dave S.
2003 Boxster S
Dave S. is offline   Reply With Quote
Old 05-24-2017, 01:30 PM   #3
Thank you Dave I'll check that out.
