Old 05-15-2017, 01:20 PM   #1
BIGJake111's Avatar
Really loud creak
My front right suspension has always had a bit of creek to it but I just noticed today that it has gotten really really bad. To the point that it creeks even from just turning the wheel. All 4 other tires are fine but up and down travel on the front right leads to a very loud creek. What should I do about this?
Old 05-15-2017, 05:25 PM   #2
BirdDog's Avatar
"All 4 other tires..."
There's your problem! You have an extra tire on your car!
Seriously though, I would have someone push down on that front right fender while you stick your head in the wheel well to localize where the sound is coming from (top of strut, strut, lower control arm, etc).
Old 05-15-2017, 05:53 PM   #3
husker boxster's Avatar
My guess would be LCA bushing. My 01S had the same issue on the left side. New bushing took care of it.
1989 928 S4 5 spd - black
Old 05-15-2017, 09:59 PM   #4
Racer Boy
Racer Boy's Avatar
Time for a new lower control arm!
Old 05-16-2017, 03:12 AM   #5
kk2002s's Avatar
+1
You may find the dust boot for that ball joint is worn allowing water and dirt in
You could try spraying WD40 in the boot
That may quite it down temporarily but still will need replacing
Old 05-16-2017, 04:50 AM   #6
+1
Or you could try a lithium grease so you actually lubricate it.
That986 is offline   Reply With Quote
Old 05-21-2017, 09:27 PM   #7
BIGJake111's Avatar
Got under and lubricated. Car seems to ride smoother and the noise while not gone is back to a similar level that it always used to be.
Old 05-22-2017, 04:41 AM   #8
Xpit77's Avatar
Did you check the sway bar link ?
DW40 may last a few days or until it rains.
99 Boxster sold
88 944S sold
Xpit Formula Four sold
95 Integra Solo I sold
71 Opel GT sold
Old 05-22-2017, 04:46 AM   #9
kk2002s's Avatar
Condition of the Dust boots?
Did you have to cut a hole or are there tears?
I did the spray lube for a year or so but eventually the lower control arms needed replacement. It took 6 month just to finally get TRW parts. I don't think they're out there any more
Seal Grey
Old 05-22-2017, 06:01 AM   #10
Project Addicted
jcslocum's Avatar
If a ball joint is creaking that bad it could blow out on you. Get it fixed!!!
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
