Old 05-01-2017, 08:08 AM   #1
2005 911/ 2001 Boxster 18" wheels
I am finding conflicting results on whether a set of wheels from a 2005 911 would be compatible with my 986 S. Spacers? Offset correct? Thanks in advance for your insight. John
JohnRedS is offline   Reply With Quote
Old 05-01-2017, 08:25 AM   #2
RedTele58's Avatar
John - you'll need to give more information about the 2005 911 wheels. There's many different sized 911 wheels depending if they came off a narrow body, wide body, turbo, etc.
At a minimum, you'll need to post the wheel width and the offset of the 911 wheel you're wanting to try. Once we have that information we can give you better help.
Old 06-27-2017, 01:57 PM   #3
Wheel fitment
Hi, I am looking at a set of Carrera Lite Wheels. I have a 2001 S, the wheel size is 18"by 7.5 front offset 50 and 18 by 9 rear 52 offset. Do I need spacers? Will these work? Thanks for looking
Old 06-27-2017, 02:41 PM   #4
Ciao's Avatar
These offsets and diameter wheel size will fit a 2001 P BoxsterS
5280 Cruising @High Altitude
Seal Gray & K&N Filter
