Old 04-02-2017, 03:05 PM   #1
Difference with this part? (LN 2QT Deep Sump Kit)
Hi All,
I just finished fitting the LN Engineering 2QT Deep Sump Oil Pan Kit inc. Pickup-Tube Extension, Windage Tray & X51 Baffle
http://lnengineering.com/2qt-deep-su...51-baffle.html
My question is in the attached pic, the top one is the oil return tube i removed from my original engine, and the bottom one (the one in my hand) is the 997 oil return tube included in the LN kit, my question is, what is the difference? was it even worth swapping out? shouldn't the new oil return tube be lower than the one i've taken out to have the same affect as the spacer for the oil pick up which also makes it lower? Im confused.
RickyG512 is offline   Reply With Quote
