Old 03-30-2017, 11:44 AM   #1
donv's Avatar
Reawakening '01 986 After Long Nap
Due to a collision of "stuff" that came up in life I have a 2001 which has been sitting unused in the garage for 5 years. It was put away with a tankful of Stabil treated fuel plus moth crystals in key places to scare away the mice. Battery died the first winter, did jump it once to get it started back then and put it on the Porsche tender from there. Has not been started since. No leaks or obvious issues from the outside.
My backup daily driver just died. Good weather is hopefully coming here to New England and my 5 year old is itching for Daddy to get the "zoomy car" going. So that's my goal.
I plan to take out the plugs and try moving the pistons manually before trying the starter. Mystery oil and a soak if they're stuck. Check the fluids. Swap over the other car's battery. Move all the stuff that's accreted around the Box so it can get out...
What else is essential to do before trying to fire it up once more?
2001 Lapis/Black/Black, PSM, Rear Speaker Kit, Optima...
donv is offline   Reply With Quote
Old 03-30-2017, 12:16 PM   #2
I am No. 1348
algiorda's Avatar
I would flush the brake fluid and the tires are probably out of round.
Current: 2004 Boxster S 550 Spyder Anniversary Edition (BSSE)
algiorda is offline   Reply With Quote
Old 03-30-2017, 12:19 PM   #3
1997 Tip, 2018 Macan
rexcramer's Avatar
Tires. They must have serious flat spots by now? And cracking? IMO, no high speed runs until you get those changed. Don't use mileage as the only criteria for replacing. Good luck and safe travels.
Old 03-30-2017, 12:20 PM   #4
donv's Avatar
Tires will be replaced, they are original and had several track days on them before the nap started. They're barely legal depth. Thx.
Old 03-30-2017, 05:22 PM   #5
Chuck W.'s Avatar
This will be interesting.... keep us posted!
1995 Porsche C4 Cab
Old 03-30-2017, 05:39 PM   #6
Fuel status?
Old 03-31-2017, 08:53 AM   #7
I would think all fluids should be checked/changed. inspect the car from underneath and make sure everything looks good. Change fuel filter maybe, easy enough to do. Not sure about proper procedures on starting an engine after 5 years but curious to see what some pros say. Good luck.
2001 Boxster 986 S, 6spd, arctic silver, black interior with black rear glass top, 18" staggered black powder-coated Porsche twists, aftermarket exhaust, smoked headlights and taillights, 20mm rear hubcentric billet wheel spacers, 5mm front billet wheel spacers, de-snorkled, passenger airbag switch, 997 shifter upgrade, LN engineering dual row update, Koni FSD with H&R sport springs, Joe Toth composites rear duck tail spoiler.
marcoc is offline   Reply With Quote
