Headlight assembly tilted in fender
I just noticed that one of my headlights is slightly out of alignment with the fender.
The top is slightly recessed and the bottom sticks out slightly. The other headlight is perfect. Its not a lot out, maybe 1/8 " I did some searching and a few threads mention it can be adjusted, but no instructions |
Look in owners manual
Look at the procedure for changing the headlight and make sure the tightening process is correct.
Its not the bulbs that need adjustment, it the entire assembly I know how to rempve and replace the the assembly. Its out of alignment |
Hopefully you don't have to adjust the tray. I had to completely adjust it when I installed a new fender. It took me a while to figure it out.
http://986forum.com/forums/uploads02...1486918434.jpg http://986forum.com/forums/uploads02...1486918450.jpg |
That's what I was looking for |
| All times are GMT -8. The time now is 01:08 PM. |
