02-02-2017, 06:36 PM
#1
Removing muffler with bumper one
For those few that have done the next to impossible of removing muffler with bumper still on, are there any special tools I will need. I viewed a link someone posted from I think fabspeed saying to remove the two 13mm nuts hidden behind the bumper but there wAs no mention of tools needed. Not sure how they gained access to them.
Also will I be able to get back on? Any surprises I should expect?
Thanks in advance.
02-02-2017, 06:45 PM
#2
Hey DWBoxx I pulled mine out without removing the bumper cover. I posted a pic in the Muffler removal thread in the DIY section. Getting to any of the bolts on top of the muffler looks tough. I'm pretty sure this is a sure case of target fixation HAHA. Anyway look at my pic in that thread. I removed the 2 nuts that attach the long flat hanger to the top of the bracket on the back of the trans. Super easy. Pull them last and install first. I used a deep socket with I think a 1" extension. Broke the nuts free and spun off with an air ratchet. Easy even without an air ratchet. Getting the clamps loose on the mid pipes and u bends was the hardest part.
How to remove muffler?
02-03-2017, 09:04 AM
#3
On my 2000 I just gave up and removed the rear bumper cover. In addition, without the cover in place it made removal of the U pipes much easier. The silver heat shields are easily taken off...I know it's more involved so resign yourself. Take your time and enjoy the process without the frustration.
02-03-2017, 09:28 AM
#4
Artist, 986S tinkerer
Having done it both ways, I would heartily recommend removing the bumper. It's quite easy and everything is SO much more accessible! YMMV
02-03-2017, 10:29 AM
#5
It actually takes less time to remove the fascia cover than to try and remove the exhaust with it on.
02-03-2017, 11:08 AM
#6
07 Carrera S Cab
The only thing to be aware of when taking the rear bumper off is that you also have to take the rear spoiler off, and that is not hard, but if you don't reinstall the metal frame of the spoiler back right, the painted spoiler lid will not fit flush (it'll sit a little higher than it should when retracted). Annoyed me, so I learned I had to resecure the bolts in the frame in the down position first and then reinstall the painted portion.
02-03-2017, 03:08 PM
#7
Aha! It's only a tiny bit higher? I think I have this problem. I'll check it out tomorrow. Thanks!
02-03-2017, 03:28 PM
#8
Hey JFP don't get me wrong I have a Great deal of respect what you do for this forum and recognize you have forgotten more than I will ever know about these cars. The way you explain problems leads me to believe that by the end of your description to a customer of how their IMS has destroyed their engine they are probably smiling and offering to buy you a cold one! But this is like saying it is easier to change the battery if you remove the hood!  I don't know how removing unnecessary body components with issues like those noted in the additional posts could be faster. I did mine on ramps and even stopping to take pictures I was done in less than an hour from start to finish. Now if I was going to pull the trans then the cover is coming off, but to just R&R the muffler....
02-03-2017, 03:53 PM
#9
Removing the fascia cover is a ten min. project, once it is out of the way and the heat shields are dropped, it another ten min. until the muffler is out. After you have done this about million times (albeit on a lift) it goes very quickly. Working around everything to drop the muffler actually takes longer, and putting it back together is even worse.
02-03-2017, 04:20 PM
#10
07 Carrera S Cab
Yes, if your spoiler lid seems a little higher than before when in the down position, that's the reason why. Secure the frame while it's all the way down and you'll be good again.
02-03-2017, 04:22 PM
#11
JFP Thanks for your willingness to discuss these cars. I have to say that once you do a task a million times it certainly becomes easier. In regards to a DIYer where time is no object, I think that minimal invasive procedure is best. This eliminates breaking brittle plastic tabs, scratches etc. While doing this on ramps is slightly restricted access and removing the fascia would open up a wonderful view. It was literally zip zip with an air ratchet (Got to get me a cordless)
Now we are having to address all fasteners, fascia on or off, the same except for potentially the hanger bolts, where do you disconnect yours? The outer ends or the inner on the bracket? I can certainly say that if I was doing this job on a lift with that kind of access, I wouldn't even consider removing the fascia even on a 98-00.
02-03-2017, 04:31 PM
#12
Inner bracket, towards the center above the gear box centerline.
How well my guys (and their families) eat depends upon beating "book" (read flat rate times) for any given job without (A) Damaging the vehicle, and (B) Not having a "come back", which they do for free on their time. On a 986, the "R&R" (remove and replace) book for the muffler is less than 3/4 of an hour; and everyone of my guys (and myself as well) remove the fascia's. On the later cars, because of the lower diffuser panel in the fascia, it is almost impossible to get the factory muffler off with the fascia cover in place without damaging the car.
02-03-2017, 04:38 PM
#13
Again Thanks; You make a living at this and still take the time. Much appreciated.
edit: Never thought about the diffuser, Guess I can do without one.......
02-03-2017, 05:14 PM
#14
I spoke to my mechanic today and was told 2hrs. I have a credit with him from before so I can have it done for under $100. No brainer. My garage is freezing and, my work space is 2x3 .
Thanks everyone for the input.
