Old 01-07-2017, 11:23 PM   #1
Abad986's Avatar
1997 986 convertible top help
Hello guys, hoping to get some help on my 1997 986.
This morning I went out to start my car and saw that it was hooking, not like the alarm just a constant honk. I unlocked it manually since my key does not work and it stoped for a little bit but then kept going. I then inserted the key to the ignition and it stoped honking but realized the numbers on the dash were faded and I assumed water got in somehow since it has been raining where I live. So I put the top down in hopes that I could let the car dry up (because it was humid inside) but as I was putting the top down, the convertible sounded a bit weak. I drove the car for about 15 min and when I went to put the top back up it tried to go up, again weak, but stoped and was just stuck about. I took it to a local convertible shop and the guy told me it was the convertible motor. Does anyone els know what it could be? I still think it just something Electricle but I'm not sure what, hoping I can find some help on here.
Thank you in advance.
Abad986 is offline   Reply With Quote
Old 01-08-2017, 01:49 PM   #2
Steve Tinker's Avatar
You may have an electrical fault, but it also sounds like a flat battery with the dash lights fading - check the voltage at the battery terminals (should be 12.6v). If less than 12.3v, charge your battery and go from there....
A 15 minute drive will not help a flat battery, you will have to charge it for at least 6-8 hours.
2001 MV Agusta F4.
Old 01-08-2017, 05:59 PM   #3
Abad986's Avatar
Hello Steve, I Checked the battery and it seems to be fine. I realized that my horn is also not working and I'm starting to think water may have got to the ECU.
Tags
convertible
