Old 12-25-2016, 05:10 PM   #1
@001 base rear speaker torn
Hello
Bought a 2001 base in October
Slowly addressing all the little things that need to be repaired
Noticed the passenger rear speaker is torn and distorting
Can anyone send a link as to how to access the rear speakers?
MIke
mike914 is offline   Reply With Quote
Old 12-25-2016, 05:21 PM   #2
Take the package shelf that contains the speakers out. With the top in the service position, there are two quarter turn plastic screws in the top of the shelf. Loosen the screws and then disconnect the speakers wire harness from the passenger side of the car (follow wires and you'll find the connector).
Once the connector is disconnected, remove the entire shelf assembly and turn it over. remove the speaker grills and you're home free. The speakers are easy to remove and replace.
Old 12-26-2016, 03:49 AM   #3
Pelican Parts has a how to article on installing the whole rear speaker kit, that may be helpful for you too.
Old 12-26-2016, 04:05 AM   #4
07 Carrera S Cab
Boxtaboy's Avatar
You can also see the video below where at 3:45, he pulls off the speaker box.
https://youtu.be/sEH9xRWcUXA
