Old 06-17-2006, 10:11 AM   #1
purple bird poop on grey soft top
Detailing project going well. Thought I was far enough away from the robin's nest, but small purple spots proved otherwise. Thoughts on safe clean up? (Don't want to ruffle the feathers of the fabric!)
getting there is offline   Reply With Quote
Old 06-17-2006, 03:26 PM   #2
Perfectlap's Avatar
REMOVE ASAP.
Use a stiff stream of water and a soft tooth brush.
NO detergent, that means if you go to a car wash don't get any soap on the
fabric top. Detergents attract dust which leads to the fabric breaking down.
Order some Raggtopp Cleaner and a bottle Raggtopp Protectant and
use a dedicated OXO feather tip brush.
and avoid parking under trees whenver possible. Last week I spent a long time cleaning the car, parked it under a tree in Supermarket parking lot for only 30 minutes minutes and the car was full of tree sap and bird bombs.
BORN: March 2000 - FINLAND
Old 06-17-2006, 07:51 PM   #3
Sound advice from Perfectlap
I had some goose droppings (I think) on my black top, went and did exactly that, stream of water on it, then used the Porsche Tequipment top cleaner and a toothbrush.....minutes later, no stains at all!
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
