12-16-2016, 02:36 AM
#1
Accessories and manuals 986 S
Boys, i need some infos, can you help me?
What kind of battery is the correct one for my Boxster S (ah? A?)
What kind of wipers are the correct one? (Bosch 3397001582 Model 582S ?)
Finally did you have links to download workshop manuals for 986 S.
Thank you in advance.
A.
Hi, i'm Antonio from Italy.
Boxter 986 S Year: 1999
12-16-2016, 05:28 AM
#2
Project Addicted
The early boxsters used 2 different sized batteries. The Tiptronic model used the larger size with more cranking amps.
H6 (48) sized battery = smaller
H7 (94R) sized = larger
Here in the USA the difference is 750 cranking amps to 830 cranking amps. Significant! I just took put an H6 and installed the H7 battery.
The H7 is longer and the hole to bolt it down is built into the base of the tray for the battery, so either size will fit.
I have not see them workshop manual online. I bought a Bently.
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
12-16-2016, 06:58 AM
#3
You can get a DVD with the manuals from John's Manuals. PDF Repair Manuals | Johns PDF Service/Shop Manuals. They are very very useful.
Anker
1941 Dodge Luxury Liner Coupe
12-16-2016, 07:15 AM
#4
Originally Posted by Anker
I would be very circumspect about buying OEM service manuals online; I am yet to see a complete version with all the necessary updates and amendments.
Anything really new is invented only in ones youth. Later, one becomes more experienced, more famous and more stupid. - Albert Einstein
12-16-2016, 10:08 AM
#6
On the slippery slope
Costco has good wiper blades for around $7-8
2004 996 Targa Tip
Instructor - San Diego region
12-16-2016, 11:48 AM
#7
I'll let others speak about the battery, but for wipers, yes, the Bosch Twin 582S is what you want.
The Twin 582S set has both blades, and they are different. The passenger side has a curve to it that more or less follows the shape of the bottom of the windshield. The driver side is straight and has a sort-of bump thing that sticks up. Not sure why that is there though...
You can probably use any cheap set of blades that fit, but if you want it to look right, the Twin 582S is what you want (aka 996 628 901 08). Shop around - prices vary a LOT - I think I paid $26 for the set but I've seen sellers on ebay selling them for $74 (CRAZY!)
PaulE - hey, thanks for that pelican link for the refills!
For the manuals, I'd recommend getting the 101 Projects book - order it directly from Pelican ($23.95 when I bought it 3 years ago), and the Bentley manual (I found Amazon was cheapest).
Hope this helps
Bill
2001 Boxster S - Speed Yellow, Black Leather, Tiptronic, Jake Raby rebuilt 3.2 with IMS Solution
12-16-2016, 03:25 PM
#8
Only problem with the Pelican and Bentley manuals is the same problem as the CD. Well, besides the copyright issue.
The print publishing weakness is that once you make a mistake, you have to sell all the old version before you can justify a new one.
Any of them will give you a general idea and be good enough for many things you'll want to do. But all contain errors.
12-20-2016, 11:35 PM
#10
Boys thank you!
For the manuals, i've found a link were download for free.
I will update you about battery and wipers...
12-20-2016, 11:37 PM
#11
12-21-2016, 12:19 AM
#12
Originally Posted by alcubot
Boys thank you!
Great. Maybe post the link for others if it's a good one
Sent from my ONE A2003 using Tapatalk
12-21-2016, 02:49 AM
#13
i've tried, but i think administrators have blocked it.
Tell me how i can do, there are many manuals...
