Boxster General Discussions
What's this noise?
11-30-2016, 03:08 PM
njbray
What's this noise?
I get this noise (sounds like a vacuum cleaner) when starting from cold. It goes off after about 20 seconds. No smoke and no cel.
Any ideas?
https://www.youtube.com/watch?v=yCEh3611i_M
11-30-2016, 03:14 PM
2
BoxsterSteve
still plays with cars...
BoxsterSteve's Garage
Udo
Your SAI pump is crapping out.
You can take these apart and lube the bearings. They dry out and make noise a while before they die.
Six speed 2000 Boxster S
11-30-2016, 03:48 PM
3
Anker
Anker's Garage
FunToy
Depends on how loud it is. Its normal to hear a faint whine.
Anker
1941 Dodge Luxury Liner Coupe
11-30-2016, 04:00 PM
4
Boxtaboy
07 Carrera S Cab
Boxtaboy's Garage
2001 Porsche Boxster
2007 Carrera S Cabriolet
Watching the video, it's abnormally loud. If he's in the U.K., is there even an SAI?
11-30-2016, 04:01 PM
5
particlewave
particlewave's Garage
F=ma
That's definitely bad/dry bushing on the secondary air pump. Easy fix and cheap if you take it apart and grease them before they burn up the motor.
11-30-2016, 04:14 PM
6
njbray
Thanks for the quick replies.
I guess I have a project for tomorrow! It looks fairly easy to remove!
Are there any write-ups for this and what type of grease is required?
11-30-2016, 05:09 PM
7
BoxsterSteve
Udo
Many VAG products use the same SAI pump. Here's a DIY I found where an Audi owner gutted his and nursed it back to life.
WRITEUP: 2.7T Secondary Air Injection SAI Pump rebuild - AudiWorld Forums
Or check with Woody... he may be able to fix you up with a decent used one.
Linear Mode
Switch to Threaded Mode
08:56 AM
