Old 10-29-2016, 11:12 AM   #1
bcinphx's Avatar
Best engine/trans cleaner??
I have purple degreaser but, it is dangerous on paint. Want to clean underside of engine and trans but, can't run the risk of getting any on paint. Ask me how I know. I have a lift and pressure washer. What is out there that will get old, heavy caked-on grime off and not harm paint?
Thanks,
Bill
02 Boxster S
01 Carrera Cab
91 BMW 850i
71 MGB GT
bcinphx is offline   Reply With Quote
Old 10-29-2016, 03:25 PM   #2
I use spray on Simple Green. Spray it on your engine then agitate with a one inch paint brush with the bristles cut a little short to make them stiffer. I rinse with a small watering can instead of a hose so it doesn't make a big mess. Works great.
fastflyer is offline   Reply With Quote
Old 10-29-2016, 04:28 PM   #3
Your engine is made of alloy. That is why it is coated with a brown wax. And everything made of alloy else is also coated with that wax, because alloy corrodes. If you remove the wax the alloy will corrode.
Regards, Markus
Old 10-29-2016, 07:15 PM   #4
Multi-Boxer Driver
Deserion's Avatar
Spray bottle with undiluted Simple Green, and another sprayer with water. Works for me.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 10-29-2016, 09:18 PM   #5
Pdwight's Avatar
What I did
Waited until the engine was stone cold in the middle of a summer day. Sprayed a mild soapy solution to break up dirt and dust.....finished with pressure washer but I never pulled the trigger.....jut the little soft spray. I avoided wiring as much as possible and let dry for 4 hour before starting car up. Harsh cleaners like the purple one are very aggressive and can shorten the lives of seals and other things....use carefully.
Old 10-29-2016, 09:31 PM   #6
bcinphx's Avatar
Thanks guys, I really want to get the grime and the grease off the bottom of the transmission and the motor - not so much on the top. It's. Caked up pretty bad from POs who did not fix leaks. And now just replaced the AOS which sprung a leak. I didn't realize that I might remove the special coating.
Bill
02 Boxster S
01 Carrera Cab
91 BMW 850i
71 MGB GT
Old 10-30-2016, 06:29 AM   #7
X3 for simple green
Woody
Old 10-30-2016, 06:36 AM   #8
bcinphx's Avatar
Thanks WOODY and thanks guys, I think I will be using simple and a garden hose first. Woody, SpecboxCO never got back to me on the cup holders.
Woody, got a good lower AOS vent hose? Clip on mine broke and I did not think I can engineer a temp fix. Plus, the intake duct for my 02 S has as separation on the hose for the resonator. I will try to silicone it but, it may not hold.
Bill
02 Boxster S
01 Carrera Cab
91 BMW 850i
71 MGB GT
Old 10-30-2016, 04:13 PM   #9
CEL P0306
Another thought: would not a few rags and elbow grease do the trick? It would seem worth a go.
aczyzewski is offline   Reply With Quote
