Old 10-11-2016, 08:19 AM   #1
Servicing clutch pedal
'02 Boxster S. I have somewhat creaking noise during moving clutch pedal. Does any one know some DIY link about the issue? Possibly greasing some critical joints or replacing a spring ...
ftp19601960 is offline   Reply With Quote
Old 10-11-2016, 01:38 PM   #2
On the slippery slope
JayG's Avatar
Could be the clutch booster spring on its way out
2004 996 Targa Tip
Instructor - San Diego region
Old 10-11-2016, 06:21 PM   #3
My recommendation - do a little testing to verify the actual source of the noise, and don't assume your first impressions are necessarily accurate.
I also have what on first glance, appeared to be a groaning clutch pedal (which I can also feel by foot). It groans when pedal is pressed and released. On first impression, I thought surely it was originating from the pedal cluster...
However, operating the clutch with the door open, and engine switched off, the source of the noise is clearly from underneath/behind the car, back in the engine/transaxle area. (Probably from the moving clutch parts that the slave cylinder actuates). I believe in my case the groaning feel must be telegraphing through the the hydraulic lines to the pedal. With engine on and door closed, there is so much noise coming from the engine/transaxle area, it was have been impossible to diagnose the source as coming from back there.
So, I recommend trying to reproduce the noise with the engine switched off, ideally in a reasonably quiet environment with a second person listening from outside the car, (or at least with door open and sticking your head outside as you actuate the pedal and listen).
Hope this helps, and ultimately puts you on the right direction for a fix! Cheers.
2001 Boxster
