Old 07-28-2016, 08:29 AM   #1
radio code
new battery radio cr 220.
followed instructions got serial number 1500059
says code is 4362
type in get and radio says wait and locks me out
help eddie
whitedogs is offline   Reply With Quote
Old 07-28-2016, 12:04 PM   #2
Heiko's Avatar
says code is 4362
help eddie
No the code should be 0472 as long as the serial is the right one
Heiko
Previously owned:
Old 07-29-2016, 06:08 AM   #3
will try it tks
Old 08-02-2016, 07:06 AM   #4
darn that code doesn't work
help
Old 08-02-2016, 07:40 AM   #5
Heiko's Avatar
help
Make sure you got the right serial number... but if it ends in 0059 then the code should be 0472.... there is a chance that 1472, 1412 or 1432 might work as alternative options in that order....
H
Previously owned:
Old 08-04-2016, 11:49 AM   #6
serial is 15000591
says code is 4362 on the radio
tks
Old 08-25-2016, 07:33 AM   #7
Heiko's Avatar
serial is 15000591
tks
Sorry I just noticed your reply... you gave me a serial ending in 0059 before
the serial ending in 0591 would generate a code of 4217 instead.
Sorry but I cant provide the correct codes if you don't send me the right serial numbers.
H
Previously owned:
Old 08-26-2016, 02:57 AM   #8
thank you Heiko will try it
like to keep original radio if possible
only use it when grand daughter in car
and top must be down lol
eddie
Old 08-26-2016, 10:31 AM   #9
thank you Heiko the code worked
my grand daughter will let me live another day
pop pop
