-   -   The oil pressure gauge...wtf. (http://986forum.com/forums/boxster-general-discussions/62373-oil-pressure-gauge-wtf.html)
FauxDiablo 07-15-2016 10:18 PM
Do I even have an oil pressure gauge?
I don't see one on the dash, and the manual only mentions an idiot light.
This idiot likes gauges, and I think I want one.
Is there an aftermarket one available specifically for the Boxster?
Deserion 07-15-2016 10:38 PM
Nope, the 986 didn't come with one. AFAIK there isn't but I'm probably wrong on that point. I do know that others have used the 996 pressure sender (two leads) when they install the 5-pod 996 cluster (which has the oil pressure gauge).
KevinH1990 07-16-2016 05:54 AM
Deserion is correct. Here are instructions for adding a 996 cluster: Porsche Boxster 996 Gauge Cluster Upgrade - 986 / 987 (1997-08) - Pelican Parts Technical Article
I was able to repair a damaged cluster and use it in my car: http://986forum.com/forums/general-discussions/43017-carrera-gauge-swap.html
I have also seen folks install aftermarket gauge packages in the area used by the storage cubbyholes or CD holders in the center of the dash.
