Old 07-02-2016, 01:37 PM   #1
Clk
996 3.4 intake manifold on 3.2 boxster
After looking around for some information i cant seem to find a solid answer so does anyone know if a 996 intake manifold will fit onto the boxster 3.2? And if so what parts will be needed for the conversion?
Clk is offline   Reply With Quote
Old 07-02-2016, 01:43 PM   #2
If it did, it would not fit under the engine cover on a Boxster as the 996 manifold is much taller.
Old 07-02-2016, 02:09 PM   #3
madmodz's Avatar
Hey JFP, how are they doing the 996 swaps in the 986 with the extra height? Are they lowering the motors to fit or not using the motor covers?
madmodz is offline   Reply With Quote
Old 07-02-2016, 02:24 PM   #4
Bit of both. Most lower the engine a couple of inches to gain clearance. The limiting factor is the fixed cross member below the bell housing area.
Old 07-02-2016, 02:54 PM   #5
Clk
Fitting a 987 engine cover should be a solution to the height of the 996 intake manifold being taller than the 986 intake
