Old 06-29-2016, 04:20 PM   #1
Boxy_02's Avatar
Trying to find leak... Does this look right?
While taking a quick look to find a vacuum line not connected, I spot this - does this look correct? If so, does anyone know what it is for? Pressure relief?
2002 Porsche Boxster Carrara White - 103,000 miles
Boxy_02 is offline   Reply With Quote
Old 06-29-2016, 04:23 PM   #2
No, that is not correct. Trace the line back and see where it goes, but the factory never did that.
Old 06-29-2016, 05:01 PM   #3
Boxy_02's Avatar
Here are some more pics. It's hard for me to see where it goes, but looks like its under the intake above the transmission.
Also, just playing around, when the A/C is on, the MAF readings jump from 2.75 g/s to 4.0 g/s at idle @ 700 rpm.
Old 06-29-2016, 06:11 PM   #4
Is the car a Tiptronic?
Old 06-29-2016, 06:12 PM   #5
Boxy_02's Avatar
Yes, it is.
Old 06-30-2016, 09:38 AM   #6
Yes, it is.
I would be willing to bet that someone has disconnected the Tiptronic cooling valve system because it had a problem, and they did not want to pay the $ to fix it correctly. If that hose traces back to the Tip, you need to reconnect it to the cooling system and fix the problem, running without the system connected is going to kill your transmission.
Old 06-30-2016, 03:39 AM   #7
Boxy_02's Avatar
All the pictures I can find show this hose routed across the middle of the Engine, but none of my manuals show what it is, or where is goes.
Old 06-30-2016, 05:01 AM   #8
Hello Boxy_02,
because i couldn't see anything on your pictures, i adjusted them. Looks like somebody fitted this line with a blind plug.
Is that photo taken from the left side of the car?
And from where did you take this photo?
Is it a 2.5 Litre engine with AT?
Regards, Markus
Old 06-30-2016, 06:16 AM   #9
Boxy_02's Avatar
Hello Boxy_02,
Regards, Markus
They were both taken from the passenger side, 2002 - 2.7L Auto.
The 2nd photo shows where the hose is going, towards the rear.
