Old 06-23-2016, 09:24 AM   #1
996 AOS in 986 Boxster
My understaning is that difference between 911/996 AOS and the one on Boxster is a coolant line. I wonder if anyone tried to use it on purpose on Boxster. I think extra cool is great for AOS operation. Why they dropped it on Boxster?
ftp19601960 is offline   Reply With Quote
Old 06-23-2016, 09:47 AM   #2
911monty's Avatar
Typically a coolant line is used to heat the (PCV). It is done to prevent icing up in negative ambient temps. It is not necessary except in Alaska or Fargo, ND.
Old 06-23-2016, 10:59 AM   #3
The use of coolant lines is to prevent icing of the AOS at low temps, which can be a problem with the 996, but not with the Boxster, which is why they did not use it.
