06-06-2016, 05:13 AM
#21
This is a situation that has to just make you scratch your head and wonder how this could go so bad in a Porsche shop.
It's like a Mafia hit: As soon as the timing was off after the replacement work, it was just a mater of turning the key to complete the hit.
It's easy to sit back and tell you how we might deal with this but you actually have to deal with it
I just hope the dealer continues to step up to and brings this to a resolution your happy with. The dealer isn't going to be happy and they will probably never do another 986 IMSB replacement again
Maybe one of those 718's just sitting around gather dust in their showroom will complete the deal
Best of... on this
Seal Grey
06-06-2016, 06:32 AM
#22
I am my own mechanic....
Any chance of a sweeeeeeeeeeeeeeet loaner??
'08 VW Touareg T-3 wife's car
06-06-2016, 08:43 AM
#23
I agree with others - the dealer needs to get you a Porsche re-manufactured motor.
Steel valves hitting aluminum pistons have most likely damaged the pistons, and probably the connecting rods, rod bearings, etc. Those bent valves probably have damaged the valve seats. Pulling the heads and replacing the valves is not an option. Engine should be pulled, completely disassembled, and every part pretty much checked. But a better, more timely solution would be a Porsche re-manufactured motor. You only had 30K miles on your original motor.
I'm really sorry this happened to you... hang in there, it can be fixed...
06-06-2016, 09:35 AM
#24
Small consolation, but they gave me a Cayenne S e-hybrid when I dropped the car off (two weeks ago). Looks as though I'll be driving it for a while.
06-06-2016, 09:36 AM
#25
Thanks. Trying to get an update from them today... no luck so far. Service Advisor is out today, Service Manager hasn't returned my call.
06-06-2016, 12:55 PM
#26
OK, I feel much better: had a conference call with the Service Manager and the Shop Foreman. They've committed to a total rebuild from top to bottom, inspecting and replacing everything that needs to be done. 2 year warranty. They seem sincere in wanting to make me whole on this. I'll get everything in writing. Estimating three to four weeks.
06-06-2016, 01:08 PM
#27
Hello kjc2050,
that sounds good to me. Fingers crossed.
Regards, Markus
06-06-2016, 01:42 PM
#28
Fantastic. Awful circumstances, but I'd take a free total rebuild.
3.6 while they're in there???
06-06-2016, 01:48 PM
#29
Don't get greedy, now.
06-06-2016, 01:57 PM
#30
1997 Tip, 2018 Macan
Great news and you get to drive the Cayenne in the mean time. Adult beverages for everybody.
06-06-2016, 06:34 PM
#31
Engine Surgeon
This is why you won't find a single dealership listed as Certified Installers of the IMS Retrofit products. Dealers are the last places that started doing these retrofits, and two years after we started selling the products, many dealers still maintained that the bearing was impossible to remove and replace.
This is way out there, and there's no telling what they actually did to create this mess. The most common issue is not checking timing first (HELLO thats part of our pre- evaluation process) and since the timing was out, it easily jumped during the procedure. They probably don;t even have the proper LN tools to lock the cams, and they are trying to use the factory tools, which increases difficulty. They may not have pulled the tensioners either.
All that said, why didn't they notice the cam timing was out before the engine was started? Its clear that they didn't, because it bent valves when it started up after the procedure.
Did the tech not check his work after completion? If he would have rolled the engine over to check cam timing, you'd not be where you are right now, and he wouldn't be looking like a fool.
Negligent techs piss me off. Please PM me the name of this dealer, and the tech. Its imperative that their accounts, and the database be updated with this bit of information, because I guarantee that if he screwed yours up, that he's done the same to others. Those might try to be turned in as warranty jobs to LN, so this is a big deal.
That said, I'd not trust anything that he did, and you better hope that he isn't the one repairing the damage/ reassembling the engine! I certainly hope that someone checked his IMS work before it went back together.
Hate to hear that this happened to you. All the "PCA members say this guy is good" talk doesn't go too far with me. Plain and simple that shop needs a QA tech thats checking cam timing before the engine is completed. Here at least 3 pair of eyes look at everything before it goes back together, and even if I am doing a job, my own employee checks MY work...(and I trained him). Thats the difference; when you treat cars like they have wings, instead of tires.
US Patent 8,992,089 &
US Patent 9,416,697
06-07-2016, 12:33 PM
#32
The problem had nothing to do with the IMS-B installation, per se. We had also agreed to install new chain guides, as I'd been seeing both brown plastic bits and green rubbery stuff in my oil filter. The camshaft deviation was rising steadily for Bank 1, as well. The tech made a mistake with regard to (not) rotating the crank at some point in the process. (Sorry, I do a lot of work on my car, but this stuff is beyond me, so if this is vague, it's me, not them.)
07-17-2016, 02:30 PM
#33
Car is back home, running absolutely perfectly. Shop foreman tore the engine down completely, replaced every part that was affected OR could have possibly been affected, including main bearings, timing chains, chain guides and ramps, etc etc etc. Here is my 30K dual row bearing:
A few other pics:
Although it took a long time (~50 days), I couldn't be happier with how the dealer handled this situation and the thoroughness with which they approached dealing with the issues. The Shop Foreman was tremendous: when I went to pick up the car we met for about a half hour, along with the CS Manager, and he walked me through exactly what had happened, and everything they did as a result. It was clear he felt horrible about what happened: I managed people for decades, and my BS meter never went off; his angst was sincere.
Next step? Drive and enjoy it, and bring it back in about 600 miles for a thorough check and oil change. Oh - the IMS bearing looked fine (for what that's worth), and turns smoothly. It goes back to LN/IMS Solution tomorrow.
07-17-2016, 02:58 PM
#34
I wouldn't accept anything short of a complete rebuild. and the fact that these guys don't sound like they know what they are doing, i would insist on an engine replacement direct from Porsche.
07-17-2016, 07:32 PM
#35
Carnut
My friend got for his 2003 base an LN IMS bearing, new clutch and other things, took 2 days and no problems. I guess it depends on the mechanic. BTW at the local dealer.
Happy to hear your dealer made it right.
'14 Boxster
07-17-2016, 07:34 PM
#36
Glad it came out well and you're good with it.
