05-20-2016, 09:02 AM
2000 Boxster S
Clutch replacement and IMS bearing inspection/upgrade in or near Italy
Hi guys,
unfortunately we don't have a Jake Raby here in Italy, nor a certified installer of retrofits and solutions - as far as I know.
I've read good reports on Hartech but the UK is too far.
I think I'm having the clutch replaced in a few months and I cannot find anybody in northern Italy with experience in IMSB inspection and upgrade.
I own a 2000 986 S with 88.000 km on the clock. It should be equipped with the double row bearing, should it not?
Any suggestions? Is there any good pro in Italy, Austria, Swiss, Germany?
Looking forward to hearing from you!
Thanks and cheers,
G.
05-20-2016, 09:31 AM
Ben-Auto-Design
If you drive a little to France you might be able to find someone to do the job!
Porsche Tech in France.
www.benautodesign.fr
1982 928 S Euro
05-20-2016, 09:40 AM
2000 Boxster S
Thank you; any name, website, FB page?
05-20-2016, 09:50 AM
2003 Base 5-speed
I think 2000MY was when they switched mid-year from double to single row IMSB, so the only way to know is to look.
05-20-2016, 09:55 AM
2000 Boxster S
Mine was first registered in Italy in January 2000, so it must have been built in 1999.
05-20-2016, 09:56 AM
Ben-Auto-Design
I found: Engine releability
It's in Cagnes sur mer, about an hour, hour and half from the frontier.
You also have: MOS Motorsport
In Nice, which is just next to Cagnes sur mer.
I've heard about Flat 06 already and I would try them first.
There might be others since the riviera is just like South Florida: There are Porsche everywhere!
1982 928 S Euro
05-20-2016, 09:57 AM
2003 Base 5-speed
If so, you're in luck as I believe the failure rate is quite low on the earlier double row
05-20-2016, 10:00 AM
2000 Boxster S
It seems more or less 1% versus 8%, right? Fingers crossed!
05-20-2016, 10:04 AM
2003 Base 5-speed
Yes, but definitely worth an inspection if you are doing the clutch. Should be no "wobble" in it.
05-20-2016, 10:13 AM
2000 Boxster S
Thanks mate!
EDIT: it seems, tough, that these are not official installers... http://www.flat69.fr, based in Lyon, are... At Flat 06 it's 2700 € for clutch and retrofit, plus petrol etc.... some 3500 €! Geez! My wife would certainly prefer Maldives rather than the South of France!
05-20-2016, 11:02 AM
Hello Gorthaur,
we have some well known and experienced independent Porsche shops over here in the Stuttgart area with guys that have formerly worked at Porsche.
But it think it's not worth to do such a long travel for just changing a clutch and an ISMB. Also it's not rocket science to do that if you have the right tools and some experience in Porsche water cooled cars and if the mechanic does his job meticulous. OK, maybe Jake will say it's rocket science.  That's OK.
Regards from Germany,
Markus
05-20-2016, 11:57 AM
Ben-Auto-Design
Lyon is almost 4h farther from italy!
Does it really matter that they are not "official installer" ? I'm not, my car still runs
1982 928 S Euro
05-20-2016, 02:39 PM
There was no clear cut-off VIN.
The only way to tell for sure is to drop the tranny and look.
05-20-2016, 03:14 PM
2000 Boxster S
No offense intended! I don't know any of them and I agree with our German friend when he says every good pro should be able to replace a d**n bearing!
05-20-2016, 03:24 PM
There Is No Substitute.
The switch happened sometime in 2001, so a MY2000 should have the double row bearing which is suspected to have less than a 1% failure rate.
05-20-2016, 06:12 PM
Ben-Auto-Design
No problem
I was just pointing that any garage can do it with the right tools
1982 928 S Euro
05-20-2016, 09:45 PM
Actually, my 2000 S had a single row.
2000 Boxster S 6 speed Guards Red
05-21-2016, 05:24 AM
Both the 2000 and 2001 model years can go either way, you should take the car apart to determine which one is in there as there is no other proven way to tell.
