Old 05-01-2016, 02:26 PM   #1
Instrument Cluster 70% Dead
Hi all,
A strange problem with 1999 2.5 Boxster which I would appreciate any help or pointers on what could fix it.
The photo shows everything that works on my dashboard, everything else is dead. For instance:
  • No Rev Counter
  • No Speedo
  • No info in any of the LED displays (although the backlights are on)
And the spoiler warning light stays on all the time! The fuel and temperature gauges work fine.
The photo shows the lights etc on the first click of the key.
Any ideas? Thanks!
blackboxster123 is offline   Reply With Quote
Old 05-01-2016, 03:05 PM   #2
I am my own mechanic....
Timco's Avatar
Is the immobilizer wet? Fresh battery? Fully charged?
Check all fuses?
'08 VW Touareg T-3 wife's car
Old 05-01-2016, 03:23 PM   #3
Pdwight's Avatar
Back to basics
Check the plugs in the back of the cluster, check each wire in the plugs to see if any have backed out for any reason...then fuses....do not look at them take a Ohm Meter and check for continuity
Old 05-01-2016, 07:13 PM   #4
cornontherob's Avatar
Fuses? Unlikely but maybe the ignition switch took a crap?
cornontherob is offline   Reply With Quote
Old 05-02-2016, 04:22 AM   #5
Project Addicted
jcslocum's Avatar
I just went thru a similar issue and the cluster was dead and there is no fixing it.
I installed a used one from Woody = itsnotanova on here. It's and easy swap with just a couple of screws and 4 plugs.
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
Old 05-02-2016, 08:00 AM   #6
CoBeerToad's Avatar
To be sure, the spoiler light stays on even after driving? Mine sometimes stays on until I start moving. I'm sure there is a good reason for this.
CoBeerToad is offline   Reply With Quote
Old 05-02-2016, 12:37 PM   #7
My guess would be that the Sensor used to register speed for raising and lowering the spoiler provides no input until the car moves. Once some input is sensed, the light goes out.
