Trunk won't open
Well, it finally happened, I was at an AX over the weekend and my trunk would not open.
I could hear the solenoid operating, but would not unlatch. Fortunately I was able to locate the emergency release cable, it was not too much of a PITA to get to. You have to remove 1 plastic nut on the rear fender liner , pull bit back with the heat shield, reach in, locate the cable and give it a good tug. Once the trunk was open, I took a look at the latch and the cable for the solenoid was broken. Didi what I normally do and looked up the part. A new one costs around $150! I didi come across a thread for repairing it Rear Trunk Latch/Opening - Pelican Parts Technical BBS Found a local hobby shop that had the part, bought a soldering gun from HF for under $15 and did the repair. Works like a charm! I am a little concerned that the cable may break again as it got a little un-woven and found a used solenoid with cable on ebay for ~$30. I think I will install that one when I get a chance and have a spare hour or so as it looks like you have to remove a bunch of stuff to get to it. At least I have a working trunk again |
I repaired mine by splicing the cable with picture wire. Works great. The dealer wanted 800 bucks to replace the cable!
I swaged some picture hanging wire or similar to the wire thjat was left. Use a sharpie, press trunk release, and see how far it retracts into the jacket tip to know where to connect to. Easy fix.
| All times are GMT -8. The time now is 06:55 AM. |
