Old 03-26-2016, 12:21 PM   #1
Ja986s's Avatar
Cool Carbon Performance brake pads for track use?
I recently picked up a set of Cool Carbon Performance pads for my 2000S. I will be using the car on the track and street.
Any experiences with this pad on the track? Street use experiences?
Thanks......
2000 Boxster S / Borla exhaust / Underdrive Pulley / EBS sump baffle / Gbox detent
2006 Cayman S (Sold)
1990 964 C2 (Sold)
1978 911 SC (Sold)
Ja986s is offline   Reply With Quote
Old 03-26-2016, 09:26 PM   #2
husker boxster's Avatar
Hi Jim. I haven't seen much on CCs here but have run across a bit of talk about them on P-9. Did some searching over there but only found a few mentions. Seemed the consensus was they are a bit rough on your rotors and will squeak but are an effective pad for a stock car.
I used Ferodo as my street & track pads on my CSS for Laguna, KS Spdwy, a cpl DEs & Fast Fri at RPM, and finally wore them out at COTA. But COTA will pretty much wear out any pad short of an orange Pagid. I went to stock pads for street and bought a set of Stop Techs on the recommendation of an avid DEer on P-9 & QuattroWorld. My first event with the Stop Techs was KS Spdwy last fall, but the event got cancelled after 3 runs due to a bonehead move by NASA. So I don't know if the Stop Techs are better or not as I was building my speed up with ea session.
I've noticed std 20 min sessions do not cause my brakes to fade but when you get the occasional 30 min session, the extra 10 min will make them fade. I try to resist the temptation of extra track time by telling myself I need to drive home when the day is done.
Are you doing spring fling at RPM? 4 of us got signed up for COTA in May. REALLY looking forward to that event.
1989 928 S4 5 spd - black
Old 03-27-2016, 06:33 AM   #3
Ja986s's Avatar
Hi Terry, yes I am signed up for the RPM event. I would love to try COTA but my summer is packed full. I hate switching pads between events but considering I am using this car on the street twice as much as I used my prior dual purpose cars, I may need to look into this. I will see you in April. Thanks......
1990 964 C2 (Sold)
1978 911 SC (Sold)
Old 03-27-2016, 07:49 AM   #4
I know, changing pads back and forth can be a pain. The putting on isn't so bad cuz I'll already have the car up and tires off to do brake fluid, but the after event is the one that is the pain.
Old 04-22-2023, 04:46 PM   #5
Porschephile
Tomikaze's Avatar
Ferodos
Are the Ferodos predrilled with holes for the pad sensors?
2004 Porsche Boxster S
Portland, Maine
Tomikaze is offline   Reply With Quote
Old 04-22-2023, 08:09 PM   #6
Nope, no holes for sensors in Ferodos. I have mine tied off and since I'm back and forth several times a yr, I'll always have an eye on pad thickness so no need for a sensor.
