Old 02-29-2016, 03:02 PM   #1
jpc763's Avatar
Door Lock Mechanism question
All,
I have decided to replace the door lock mechanism and the window microswitch on my passenger door in order to try to eliminate my alarm system problems. I have a thread here and on RennTech and pretty much it seems that the problem is with the microswitches, probably the window one, but possibly the door lock ones.
So, I looked on Pelican and they have the part number as 8N1-837-016-C-VAG. A quick search on that shows it is a shared part with Audi TT (and others) and possibly Volkswagons as well.
Is that accurate?
Thanks, John
2001 Boxster S - Midnight Blue Metalic
jpc763 is offline   Reply With Quote
Old 02-29-2016, 04:11 PM   #2
There Is No Substitute.
rick3000's Avatar
That part number is in the official 986 Parts Catalogue (link) for the passenger side door lock MY98+. I am not surprised it is also a VW/Audi part, there are a couple of those in the 986.
Old 02-29-2016, 10:42 PM   #3
BoxsterPHD's Avatar
I fitted this VW door lock to my 2001 986 (passenger side UK)
http://www.ebay.co.uk/itm/Door-Lock-Mechanism-For-VW-Golf-MK5-Front-Left-Touareg-Touran-Toledo-UK-Stock-/281812056176?hash=item419d4eb870:g:wFAAAOSwKIpWCRP R
Sent from my Hudl 2 using Tapatalk
BoxsterPHD is offline   Reply With Quote
Old 03-01-2016, 10:23 AM   #4
jpc763's Avatar
Originally Posted by BoxsterPHD View Post
Thanks!
Are the microswitches included?
Old 03-01-2016, 01:24 PM   #5
BoxsterPHD's Avatar
The passenger door lock (like the one I used in the link) has 3 microswitches built into it: door opened/closed, door locked/unlocked and safe contact. The door opened/closed microswitch affects the window drop function by causing your window to not drop or stay dropped or go up and down randomly. The only other microswitches in the door are attached to the door handles and they activate the window drop function, but only when the door opened/closed switch tells the CLU that the door is closed. The driver's door lock has an extra microswitch which lets the CLU know when they key is turned to the open/closed position. All the microswitches apart from the door handle ones come as part of the door lock.
Old 03-01-2016, 01:28 PM   #6
BoxsterPHD's Avatar
Here's a pic of the microswitches on my old lock.
Old 03-22-2016, 11:55 AM   #7
jpc763's Avatar
An update. I purchased a passenger door lock mechanism from Woody and installed it over the weekend. So far, I have not had the problem again. No beep beep. No alarm light. The window drops when the passenger door is opened. Pretty happy so far!
Old 03-28-2016, 01:17 AM   #8
EJ-Fresno's Avatar
How did you manage to remove the defect one? I tried replacing mine but I couldn't get the old one out, because of the frame...
Thanks.
2003 2.7 Boxster - Tiptronic - Carrera wheels - OBC - Red calipers - Cat pipes - Modified muffler - Rear speakers - K&N - Litronics
2006 V6 Mustang
2008 ML 350
EJ-Fresno is offline   Reply With Quote
Old 04-26-2016, 01:00 AM   #9
Originally Posted by jpc763 View Post
... I looked on Pelican and they have the part number as 8N1-837-016-C-VAG. A quick search on that shows it is a shared part with Audi TT (and others) and possibly Volkswagons as well.
John,
How did you check the part number equivalence between Porsche and Audi/VW ?
I have a problem on the driver side (left hand drive). It wont lock/unlock, while the passenger lock locks/unlocks and the instrument panel button works as well.
/Jonas
jonasab is offline   Reply With Quote
