Old 02-28-2016, 11:07 AM   #1
Increase your Power-to-Weight ratio
... By removing ~2lbs. of bugs, rocks and leaves from your radiators!
2000 Boxster S 6 speed Guards Red
AaronPDX is offline   Reply With Quote
Old 02-28-2016, 11:18 AM   #2
Luv2Box's Avatar
Then install these so you don't have to do that anymore.
Luv2Box is offline   Reply With Quote
Old 02-28-2016, 11:41 AM   #3
Just curious, Did you manufacture the screen guards or did you buy them? If so, where did you buy them? Thx
Richardbruce is offline   Reply With Quote
Old 02-28-2016, 12:27 PM   #4
There Is No Substitute.
rick3000's Avatar
You can buy them for around $70+, most people go to Home Depot or Lowe's and buy gutter guard for about $4. It only takes a few minutes with some wire snips and pliers to bend them into the right shape. With either option you have to remove the bumper.
Old 02-28-2016, 02:24 PM   #5
2003 Base 5-speed
grc0456's Avatar
Yup.....they do need a regular clean out if you don't have the screens. Not sure I like the look of the screens, though.
Old 02-28-2016, 03:40 PM   #6
Luv2Box's Avatar
I bought mine at ******************************************** (or Automobile Atlanta) and they mount from the outside using butterfly screws so install is easy and they can be removed to repaint. They have a rubber liner around them and came unpainted. I sprayed them with truck bed liner. They look quite nice but more importantly they work so you don't have to keep removing your front bumper to clean the crude out.
Old 02-28-2016, 09:40 PM   #7
I'm with you. I'm not a huge fan of the screened look. I'll probably just stick to regular cleanings (this was my first since buying it).
