Old 02-19-2016, 06:36 AM   #1
mikesz's Avatar
OBC 4-stalk mod question
I have a 99 Boxster base. Bought a 4-stalk from a forum member and bought a wiring harness from Dwight.
1st question I have the OLD guage cluster, black, white and blue plugs. Based on what I have seen the obc harness connects to the white plug. is this correct?
2nd question does anyone have or can give me a layout of the plug and where the 4 harness wires should be input to the back of the plug. the problem is the plug has each port numbered but at 55 even with glasses and a magnifying glass I cannot "see" the numbers.
sucks getting old!
99 Porsche Boxster
Old 02-19-2016, 08:02 AM   #2
apswater's Avatar
Full instructions.
http://www.pelicanparts.com/techarticles/Boxster_Tech/91-ELEC-turn_signal_switch_-_OBC_upgrade/91-ELEC-turn_signal_switch_-_OBC_upgrade.htm
Dwights terminals are a little larger than the right ones but you can force them in. The ones called out for in the Pelican instructions fit better and can be removed easily if necessary.
You might need a magnifying glass to get the right numbers (there is an app for that) but they should be the open slots.
SciGuy
2000 Boxster S (13K miles)
apswater is offline   Reply With Quote
