Old 02-09-2016, 11:17 AM   #1
Convertible top will not operate
I have replaced everything but the panel rocker switch and ebrake switch which i know is good because the cluster light comes on when brake is on. I know the motor works and will open and close the top because i hot wired it to test it. What am i missing? If anyone has any tips to help figure this out it would be much appreciated.
markkatri is offline   Reply With Quote
Old 02-09-2016, 03:26 PM   #2
Might there have been any binding when completed? Could it have blown a fuse?
Lapister is offline   Reply With Quote
Old 02-09-2016, 03:35 PM   #3
Fuse or relay.
Sassmatt72 is offline   Reply With Quote
Old 02-09-2016, 04:03 PM   #4
Retroman1969's Avatar
My light would come on with the parking brake, but the switch was bad anyway. That's usually the most common culprit when the top suddenly stops working.
Old 02-09-2016, 04:54 PM   #5
Absolutely correct! I bypassed my switch when it went bad and would not allow me to operate my top. The bypass allows you to open/close roof while in motion.
By parking brake light still works when I use the parking brake.
Old 02-09-2016, 04:37 PM   #6
I never knew the light could work but signal not. Good info. Thx
Tags
conv. top wont close
