Old 01-27-2016, 05:05 PM   #1
Transmission noise (with video file)
My 2000 S has a noise coming from the transmission in idle - sounds like a rattle noise. It's random and doesn't happen all the time. When I push in the clutch it goes away. I put a wood stick on the rear of the transmission case and listen through it and it sure sounds like the transmission is the source. Here is a video where I also put the camera on the stick to adsorb the vibration noise. Any thoughts?
https://www.youtube.com/watch?v=I85tIVwc89Q&feature=youtu.be
Old 01-27-2016, 07:43 PM   #2
Mig
if it was my car, I would find a quiet road, bring the car up to speed, put it in neutral, turn off the engine, and see how it sounds at speed with the engine off.
Yes, I realize this can be considered risky driving, but the test could tell you if the noise is independent of the engine.
Mig is offline   Reply With Quote
Old 01-27-2016, 08:05 PM   #3
epapp's Avatar
Does the sound change when you are moving and have the clutch in/out?
It sure sounds like a single cylinder or valve/lifter assembly knocking because of its frequency at idle.
