Old 01-11-2016, 04:29 AM   #1
02 headlight retention bar/tool stripped
Removed headlight using tool OK
On reinstall tool felt to be skipping
Removed headlight held bar and confirmed tool skipping
Tool is from pouch in tool kit, looks OK
Unsure if tool or bar end is stripped
What is suggested next step?
Will a standard 5mm socket work, or too thick?
Ancosta is offline   Reply With Quote
Old 01-11-2016, 04:32 AM   #2
5mm from a 1/4 drive set works for me.
2001 Boxster S, TipTronic in Seal Grey aka "The Imp"
2001 TE50, ESS in (now) Grigio Titanio Matallizzato aka "The Golden child"
TrumpyAl is offline   Reply With Quote
Old 01-11-2016, 06:09 AM   #3
Funny you mention this. I replaced my halogens with Litronics yesterday and the tool would not release after locking one of the headlights in place. I finally got it off after removing the headlight a few times and the tool looks buggered up a bit.
rjh986 is offline   Reply With Quote
Old 01-11-2016, 09:23 AM   #4
pony13ca's Avatar
+1, My car didn't have the tool in the kit. I haven't had any issues using the socket.
pony13ca is offline   Reply With Quote
Old 01-11-2016, 09:33 AM   #5
RedTele58's Avatar
Using the socket is fine.
Headlights tend to get tricky when installing. I've had the same thing happening to you happen to me. Patience is the key. You'll eventually get everything lined up just right and they'll slip into place.
