Old 01-05-2016, 12:22 PM   #1
Finnegan's Avatar
Burning plastic smell
Hi All,
After a long-ish drive (3 hours or so) I noticed a burning plastic smell. It was stronger on the passenger side, and seemed to be coming from the vent or engine area. There was no smoke.
I had it up on a lift getting an alignment done this morning and poked around looking for anything suspect but didn't see the source.
Any ideas?
Old 01-05-2016, 12:39 PM   #2
Could be a spark plug tube leaking and dripping an occasional drop of oil on the cat/exhaust.
Wret is offline   Reply With Quote
Old 01-05-2016, 04:14 PM   #3
Fintro11's Avatar
I found that crap they are putting on the roads right now leaves a weird burning smell on the exhaust after going for a drive
Old 01-05-2016, 04:58 PM   #4
JayG's Avatar
eau de Porsche
Old 01-06-2016, 05:21 AM   #5
2003 Base 5-speed
grc0456's Avatar
eau de Porsche
Haaaaaaaaaa!
Old 01-06-2016, 10:12 AM   #6
Finnegan's Avatar
My indie mechanic suggests a dye to track down the leak. Does that seem reasonable?
Old 01-06-2016, 11:08 AM   #7
78F350's Avatar
Too bad you can't post the smell.
A few non engine oil burning smells I can think of:
-The right side engine compartment cooling fan.
-AC compressor clutch.
-Idler pulleys/belt melt.
-Grease from a torn CV boot slung onto the exhaust shielding.
Old 01-06-2016, 12:10 PM   #8
Finnegan's Avatar
A few months ago I had a plastic bag caught on the exhaust and it made a similar smell. Mechanic is going to 'add dye' today, let me run it for ~150 miles, and then check it. We'll see what they can find.
Old 01-07-2016, 04:59 AM   #9
mikesz's Avatar
I had a similar problem with my car. Indy and dealer could not figure it out. Finally I determined one of my coolant fans was binding causing fuse block to fry.
99 Porsche Boxster
Old 01-13-2016, 03:07 PM   #10
Finnegan's Avatar
Well, the car doc says, we don't know. There was a tiny bit of oil around the drain plug, and a tiny bit near the oil fill neck. But that was it, and nothing to account for the smell I was getting. It has been intermittent and of course there was no smell today. They said bring it back if it gets worse.
No news is good news?
