Old 12-26-2015, 09:51 AM   #1
KevinH1990's Avatar
Light Switch - Constant Illumination
The light switch on the dashboard in my 2000 Boxster is illuminated all the time.
I think that it may be related to my recent replacement of the ignition switch. My ignition key would not come out of the ignition switch, so I replaced the electrical part with the Audi part. I used the replacement procedure that includes removing the left side vent trim piece that holds the ignition switch. This fixed the key-removal issue, but it seems like soon after I noticed that the ignition switch lighting was constantly on. Even when the car is totally off and locked, I can see the light switch illuminated.
About a year ago, I added a set of litronic headlights with the self-leveling feature. I've seen some posts that indicate that the litronics may add some stress to the light switch causing it to fail. So, that could be a contributing factor.
Before I start throwing parts at the problem by changing the light switch, I'm wondering whether anyone else has had a similar problem and found the solution. Also, are there any options other than the Porsche part?
