Old 05-24-2017, 05:35 PM   #1
Shacky
New Sway Bar Bushings all around - Wow!!!!
Had rattle and my mechanic said all 4 bushings were shot. Rattle gone and wow what an improvement!!!
If you have an older 986 lik mine ('99) well worth it!!!
shacky is offline   Reply With Quote
Old 05-24-2017, 09:17 PM   #2
Pdwight's Avatar
Might be a good PM measure for all of us
Old 05-24-2017, 09:22 PM   #3
Pdwight's Avatar
two different ones
Pelican shows two different ones for the rear ??
Same year ??
The front set only a single variation
Is this an S thing or what Pelican Parts
This would be an easy PM measure to do
Old 05-24-2017, 10:37 PM   #4
According to the Porsche 986 USA parts "katalog", there are 3 different part numbers for rear swaybar bushings, depending on the swaybar diameter, which depends on the car's options:
996 333 792 24 (18.7mm swaybar diameter),
996 333 792 28 (19.2mm swaybar diameter), and
996 333 792 25 (19.7mm swaybar diameter).
For front swaybar bushings, there are also 3 options:
996 343 792 14 (for thinnest swaybar),
996 343 792 12 (for medium thickness swaybar) and
996 343 792 17 (for thickest swaybar).
I'd recommend measuring the actual od of the swaybars on your car with calipers, although you'll need to research front swaybar diameters, to be sure. You can also look up specific options on your car in the parts catalog.
It's possible that there are superceded part numbers, but hope this helps.
2001 Boxster
Old 05-25-2017, 03:48 PM   #5
Shacky
My indie only charged me $120 for labor and that included oil change!
I didn't realize how bad my car was! Well worth it.
