-   -   AOS and fuel filter Question (http://986forum.com/forums/boxster-general-discussions/59236-aos-fuel-filter-question.html)
DWBOX2000 10-21-2015 06:16 PM
I was thinking about replacing the AOS on my 2000 Boxster S with just under 50k. I recently cleaned the throttle body and noticed it was very clean. Is this a sign that I can likely wait on the replacing the AOS?
Regarding the Fuel Filter, I though I read to change at about 60K. Does that still apply if the car is 15 years old?
Thanks,
David
dghii 10-21-2015 06:39 PM
Hi David,
I would hold off on replacing the AOS unless I was getting ready for a long trip or something like that. You'll know when it happens!
As for the fuel filter, its pretty easy to change so just do it when you change your oil (or oil, or motor mount, or water pump...).
DWBOX2000 10-21-2015 07:13 PM
Thanks for responding. I guess I will wait.
Pdwight 10-21-2015 08:35 PM
Oil cap test
I did the oil cap test
Car warmed up idling
see if you can remove the oil filler cap
I could without a lot of effort...so I am putting this off for a while
