Old 10-06-2015, 11:48 AM   #1
Adjusting emergency brake
Can anybody help me out? I am trying to adjust my emergency brake and the process seems to be easy by reading it in the 101 projects book.
I can't break the nuts loose that are under the center console. There are two nuts on a long bolt that need to be loosened in order to give the cables some slack. Any ideas on how to get these nuts loose? Do they turn in opposite directions?
'04 Boxster S - Basalt Black, Fabspeed exhaust and sport headers, UD pulley, Pedro's Bluetooth, 18" Cayman S wheels, Evo cold air intake, IPD plenum, 74mm TB, Ben's SSK with ICT shifter boot, Fabspeed ECU Tune.
F18febe is offline   Reply With Quote
Old 10-06-2015, 12:02 PM   #2
98 Arctic silver 986
tommy583's Avatar
Hold the nut closest to the cable with one wrench and turn the other nut to loosen.
Old 10-06-2015, 12:05 PM   #3
I did that and I still couldn't break the nut loose. Do they turn in opposite directions on is it still lefty loosey righty tighty for both?
Old 10-06-2015, 12:34 PM   #4
tommy583's Avatar
Just to make sure we are talking about the same part.
http://www.pelicanparts.com/techarticles/Boxster_Tech/51-BRAKES-Parking_Brake_Adjustment/images_large/pic2.jpg
You loosen the nut with the yellow arrow. It should loosen the regular direction.
Old 10-06-2015, 04:53 PM   #5
Project Addicted
jcslocum's Avatar
They are both right hand thread. Just hold the inner nut and turn the other nut counter clockwise or loose. The nuts are jammed tight so it takes some effort.
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
