-   -   rough idling on 986S (http://986forum.com/forums/boxster-general-discussions/59024-rough-idling-986s.html)
ArmenT 10-05-2015 10:32 AM
hi all,
I'm experiencing idling issue on my 986S, manual transmission, 80K (AOS is new, only 2k on it). I'm thinking of changing MAF sensor and clean throttle body, but before that I would like to see what you guys think about. Attached picture is RPM graph that I captured with my phone.
Thanks.
Regards,
Armen
http://986forum.com/forums/uploads01/rpm1444066182.jpg
pony13ca 10-05-2015 11:06 AM
Clean the MAF. I got mine wet/dirty a little while ago, and not only did it idle poorly, it was throwing misfire codes. Got the MAF clean and dry, and all issues were gone.
Gilles 10-05-2015 11:32 AM
Perhaps a vaccum leak ..?
epapp 10-05-2015 01:03 PM
Looks more suspect than a MAF, since the idle is consistently so low. I would think there is a vacuum leak somewhere. Do you have any fault codes stored?
If it were just MAF instability, I would expect a more average RPM of 750.
BIGJake111 10-05-2015 01:26 PM
I had a similar issue, similar mileage and AOS just replaced as well.
For me it was a pinched seal on the new AOS. Make sure everything is hooked up well back there.
Despite the pinched seal I didn't have a light thrown for a long time after the AOS was installed.
ArmenT 10-05-2015 05:12 PM
guys thanks for input.
I dont have any codes, everything clean. I opened engine oil cap when car was running and RPMs jump up about 100-150rpm.So I guess its not a major vacuum leak or could be a small leak? I changed AOS myself last year and the main reason I replaced it was idling.I never cleaned throttle body and MAF since I purchased car back in 2013, maybe that a good place to start.
Thanks.
thom4782 10-05-2015 09:03 PM
It could be a dirty throttle body, which has a hunting idle as one symptom. Saw this on my 01S. Once the TB was cleaned the idle returned to rock steady.
epapp 10-06-2015 08:31 AM
Certainly clean the TB and MAF first. Pretty easy to take the intake tubing/MAF, TB off and spray around with MAF cleaner. A battery disconnect normally helps after cleaning MAF and TB too.
nieuwhzn 10-06-2015 09:28 PM
Taking the throttle body out is easier when it's warm. You're lucky that you are in LA. The rubber stuff is a ******************** when trying to get the throttle body back in.
