04-27-2006, 06:07 AM
#1
The alpha and the omega
Several years ago, I sold a 2000 Boxster to my neighbor. She loved it so much, she went out and bought a new 04 last year.
On Tuesday, the half shaft let go and, well, in short, goodbye to the engine.
Talk about upset, she is!
The good news is that the new engine should be in by Friday or Monday, no charge.
The bad news is the car is now "suspect" in her eyes. She wants to know why an engine with 10K miles on it should fail while sitting at a stop sign.
I did not have a good answer for her.
Is Stuttgard listening?
Rich Belloff
04-27-2006, 06:42 AM
#2
sitting at a stop sign, eh? maybe she wasn't supposed to proceed past the stop sign - in other words, perhaps devastating consequences would have ensued had she continued on her journey. Maybe the blown engine kept her (or somebody else) alive that day. if i could only get that phonebooth time machine sitting in the garage up and working!
Mach Schnell
05 Mini Cooper S
CR/W - AC Schnitzerz'd, Alta CAI, Cravenspeed SSK
Japanese Rising Sun roof graphic
De-ambered and nearly de-chromed!
Sold - 05 BMW 330CI ZHP M-tuned
Imola Red, 6spd, Alcantra & Carbon Fiber Interior
Sold - 05 Boxster Black/Black 5spd
19" Carrera S Wheels
Bose Audio System/Sport Chrono Pkg
Schnell Short Shifter
Yellow Calipers c/ carbon fiber Porsche lettering
De-Ambered
Sold - 03 VW Beetle Silver - way too modified!
04-27-2006, 06:46 AM
#3
You are right.
Perhaps the Porsche engineers are so god like, they could foresee this tragedy about to happen. Hence, the design-in failure to keep her safe!
Why didn't I think of that?
:dance:
Rich Belloff
04-27-2006, 07:16 AM
#4
Bruce,
By half-shaft I think you're talking about the Intermediate Shaft. In '03 I believe, Porsche re-engineered this piece and went from a Double- Bearing at the end to a Single-Bearing one, supposedly to reduce vibration.
The intermediate shaft drives the oil pump. When the Intermediate Shaft breaks, a small stud which protrudes from the Intermediate Shaft Flange Seal breaks off and rattles around in the Bell Housing - Not Good!
From the flywheel side of the engine a 13mm nut is centered in the Intermediate Shaft Flange Seal. That nut and the stud its attached to is what breaks. This causes Oil to pour out of the hole left in the middle of the Flange Seal.
At this point in the Failure, the Crank is still driving the intermediate shaft so Oil Pressure is maintained. But, once the engine is stopped, Oil just flows from it similar to catastrophic RMS Failure.
The Intermediate Shaft also drives the Camshafts. The Intermediate Shaft has two Sprockets at one end and one at the other . The end with two Sprockets has one Sprocket for the Drive Chain from the Crank, the other drives the Cams. So, in addition to piercing the Oil Flange Seal when the Shaft breaks, causing the Oil to drain from the Engine, it can also interupt the Valve Timing. The M96 Engine is an Interference Engine and so when breakage occurs, you can also bend Valves and Crack Pistons - also NOT Good.
Unlike RMS Failure, which tends to occur on Cars under 20k mi., the Intermediate Shaft can fail even at higher mileage, but is less common than RMS issues. Although not restricted to post '02 models, it does seem more prevalent in them. While less common than RMS Failure, Intermediate Shaft Failure almost always destroys the Engine when it goes. There is no maintenance or Driving Practice known to reduce the likelyhood of such a failure. Hope this helps...
Happy Motoring!... Jim'99
04-27-2006, 07:24 AM
#5
First, great explanation, Jim.
Second - wonder if they'll go back to a double bearing. Maybe a little vibration is not so bad after all?
Anybody know if there are any major engine redesigns in the works, or is it status quo for a few more years?
04-27-2006, 08:00 AM
#6
I find it kind of appalling that this kind of design issue shows up on an engine that has been out since 1997.
What is Porsche's motto?
Rich Belloff
04-27-2006, 01:29 PM
#7
Porsche put us thru this with with the notorious cam timing chain tensioners that failed with disasterous consequences if you were at high rpm. Fortunately my 911 went slowly, albeit noisily.
And a stop-lite failure would probably not be catastrophic. Porsche finally fixed the problem with additional lubrication, but it was in the mid-80s (MY84 Ronzi said in earlier post)
Mike
04 Boxster S - Basalt/Savanna, 6sp, Carrera lites, hardtop
70 914-6 - Black over tan, original/stock
PCA since 1970
Reason: give credit
04-27-2006, 07:04 PM
#8
RMS - all years
Cylinder Liners - 98-99
Intermediate Shaft - 02 and up
i guess youre screwed no matter what
04-27-2006, 07:22 PM
#9
Originally Posted by Finallygottaporsche
RMS - all years
I second that.... After owning 5 Porsches and other euro makes(BMW, MB, Land Rover, VW), i can safely say that the overall quality of Euro cars are just deteriorating over the years. If it is reliability you are looking for, id definitely switch to Japanese engineering(Toyota/Lexus, Honda, etc...). It is really a sad trend.
04-28-2006, 06:39 AM
#10
I do think the German car makers have serious quality issues and I am not talking loose cupholders or a rattle or two.
This is too bad, as they DO make wonderful cars to drive.
This has been happening for many years and does NOT appear to be an diminishing problem for them.
Now that Lexus has targetted Europe ........
Rich Belloff
04-28-2006, 07:25 AM
#11
RMS - all years
sounds like a 2000-2001 Boxster is the sweet spot
(for avoiding the statistical possibility of a major engine failure)
BORN: March 2000 - FINLAND
04-28-2006, 07:42 AM
#12
RMS - all years
I've heard so many "explanations" about cylinder liners, intermediate shafts, what causes the problem, and their "effective" dates. I call B.S.
I've seen and heard about way too many intermediate shaft failures from 97 - 2003. This is NOT limited to 02 and up.
What pisses me off about all of this is that I found a really nice '03 S and the only thing keeping me from it is the thought of another engine failure - this time out of warranty.
'06 Cayenne Turbo S, Beige Metallic/Tan
Ex - '99 Arctic Silver, Red Interior, Silver Top
04-28-2006, 08:22 AM
#13
i love driving German cars. Porsches and BMWs communicate with the driver in a way that very few cars do. i will continue to drive German cars
for the time being because of performance. i will just try to drive cars that are still under warranty so there is no engine reaplacement issue to deal with.
04-28-2006, 08:43 AM
#14
That is pretty much my take on it.
Rich Belloff
04-28-2006, 05:18 PM
#15
Is it true that 911's have far less problems than our Box? A mechanic down in Aliso Veijo told me this once, and when I stopped by the Norwalk Dealer, I noticed that the shop was full of boxsters raised up.
04-28-2006, 07:48 PM
#16
Subjectively I believe this is true yet I have no data on this.
Rich Belloff
04-28-2006, 07:58 PM
#17
Talking about older Porsches. I used to have a 1986 944. It came with a broken water cooler, i had my trusted mechanic change everything under the hood since i decided to use it as an everyday car 5 yrs ago. A new valve job, head resurfaced, new water pump, new alternator, all new belts/filters/seals...etc ..etc (all parts courtesy of Vertex auto in Miami). To cut my sweet story short, I sold the car to my best friend 2 years ago. Im happy to report that it's been 85k since the last engine refurbishing. ABSOLUTELY NO problems, Never stalled on me...Nothing,after 85k mi!...BTW, The Original A/C still blows cold!...Now thats REAL reliability!...i wish i can say that to newer Euro cars
