08-22-2015, 03:56 PM
Looking to enter the Porsche family...not sure what to get.
Hello all. This is my first post and I'm trying to research which Boxster to get. I am not going new as its a bit high for me. I've narrowed it down to between a 2005 to a 2009 Boxster.
My question is are there years to avoid? Boxster vs Boxster S. I need help please.
08-22-2015, 04:11 PM
An 09 and newer car with a 9A1 engine is better value for money while being more expensive. That being said there isn't much different between an 05 and 08. So maybe a slightly older S would be a better buy then a base.
08-22-2015, 04:37 PM
Thank you BigJake. Would you say there are any years to avoid?
08-22-2015, 05:13 PM
You'll get better info from a 987 forum. You might try rennlist.
08-22-2015, 05:44 PM
Beginner
Big Jake nailed it. Get the S if you want a little more performance, get as new as you can. Be aware of the IMSB issue, and buy a newer Boxster without one if it bothers you.
2003 S manual
08-22-2015, 05:54 PM
I would go with an 06 at the minimum in that age range. Beefier IMS for starters. But an 09 is the way to go if budget allows, IMO. An S is a nice upgrade, but if you've never had a Sportscar before, the base will still wow you.
08-22-2015, 06:09 PM
I recently went from a 1st gen 986 to a 2009 Cayman. The 09 is a lot more car, lot more $$. You should be able to find a nice lo mi 2009 car for around $30k.
08-22-2015, 07:17 PM
09 and up for sure.
08-22-2015, 08:07 PM
I think 09 was also the first year for the PDK
I could be wrong.....
08-22-2015, 08:45 PM
In my opinion, you should look for the one with the lowest mileage you can afford. As S is better than a base but a base is still very enjoyable. The IMS bearing thing is very over stated but when you change the clutch, upgrade the bearing. I recently picked up a 2000 S with 12,000 miles for a great price. You never know what you are going to find. Just keep looking for ultra low miles and dont worry about the year so much.
SciGuy
2000 Boxster S (13K miles)
08-23-2015, 06:03 AM
08-24-2015, 12:43 PM
Nice car! You will love it. And the mileage is just right, low enough to be a good value over the long haul but you are over 40K so the danger of IMS failure is much lower now. Make sure you get a pre purchase inspection from a good Porsche mechanic!
