Old 08-22-2015, 10:34 AM   #1
ABS/PCM warning
Hello all,
I have a 986 2003 3.2s
The abs/pcm warning has appeared on the dashboard - the diagnostics identified the abs pressure sensor to be the cause so after having created a hard fault to confirm the error I changed the sensor -
The error was eliminated for a couple of days and has returned - it does however vanish if you switch the ignition off then wait, then back on.
It doesn't ever appear whilst driving !
Any ideas?
Change the brake fluid has been suggested , to eliminate any air or contamination -
this is driving me mad - any help appreciated...........
rossa123 is offline   Reply With Quote
Old 09-09-2015, 09:27 AM   #2
Although no one has replied I changed the brake fluid -
the warnings vanished for a week and are now back - could this be due to the master brake cylinder being warn-
the brake pedal does appear "softer" than in my 986 2.7
